View unanswered posts | View active topics It is currently July 26th, 2025, 6:18 pm
Reply to topic  [ 3993 posts ]  Go to page Previous  1 ... 69, 70, 71, 72, 73, 74, 75 ... 400  Next
ken wrote:
ayjay,
it unplugs easily.
Don't destroy it, as I've found a use for them on Dyanes... ;)
ayjay wrote:
i neverv get round to doing things ken
i didn,t realise the diode needed to be removed aswell :?:
i know where its located so ill snip it or maybye i can get it apart and remove said diode
cheers ken :D
ok ken, i had a look and it has a yellow plug at the end if u want the diode its yours for free of course :D
December 16th, 2012, 10:39 pm
Finally solved the clunking suspension.
Having diagnosed the issue as a worn tie rod end, I replaced that.
Diagnosis was wrong.
Then realised the entire suspension can on one side was loose, tightened it up - luckily a friend with better technical knowledge pointed out that the washer that folds over to prevent the big nut coming undone hadn't been folded over.
So hammered that, and the suspension is solid as a rock and the van much much quieter to drive!
December 17th, 2012, 11:44 am
Haggis Muncher
Sprayed a good chunk of a can of wd-40 all over the suspension nuts an bolts, hoping a similar treatment every day for a week will free things up enough for an over-xmas suspension overhaul to sort out the almighty bangs, judders and endless pitching and rolling caused by passing over even the tiniest of grains of dust on the road...
December 17th, 2012, 1:31 pm
ken wrote:
D6,
doesn't a Renault 6 have more in common with this creation, than with a Dyane, on a 'drive-by assessment' at least? :lol:
http://img7.autonavigator.ru/carsfoto/1 ... ch_427.jpg
Well yes but they did remember to fit the brakes on the R 6! :lol:
m
Mike
December 17th, 2012, 2:50 pm
Had a poke around under the Ami; my wot big holes we have in our outer toe board & front cills :o
This doth not a happy bunny make... :roll:
Mike
December 17th, 2012, 8:44 pm
a mig welder doeth one buy :D
December 17th, 2012, 11:49 pm
Haggis Muncher
I found lots of them too - i covered them with rust eater & gorilla tape and pretended they didnt exist... :lol:
December 17th, 2012, 11:58 pm
Discovered that the carb was half full of water :(
December 18th, 2012, 12:52 am
Covering it all in mud, salt & pig shit for the winter and then maybe in the spring will all be gone?! :shock: Erm... that's the holes not the whole Ami, I hope. Tho no doubt it'll be me making the whole holes gone in the spring... :roll:
My mig is a pig, points made recently on here about buying a decent one noted, but I have an inverter stick welder and some 1.5mm rods which welded up the floor on the 87 Special last year so that might work...
Mike
December 18th, 2012, 3:19 am
proper fuel cap or one of those plastic garage forecourt replacements?
suspect also the small piece of fuel pipe on top of the tank and the run down by the front wheel under the fuel pump - any cracking in these areas means the pump will draw in water when its wet and leak(smell) slightly when stopped
also check the piece of rubber that joins tank to filler pipe is on , tight and the metal liguarex/jubilee clips are tight and not corroded and burst.
December 18th, 2012, 9:20 am
