View unanswered posts | View active topics It is currently July 23rd, 2025, 6:43 am
Reply to topic  [ 3993 posts ]  Go to page Previous  1 ... 53, 54, 55, 56, 57, 58, 59 ... 400  Next
Rhythm Thief wrote:
.............. Tomorrow's job will be to ..... work out why it runs out of fuel in the float chambers when I corner on the doorhandles.
My [1988reg] 2CV displayed similar problems when the fuel pump was virtually worn out ......it was notably worse on R/H bends and when driven "enthusiastically" round roundabouts ......after checking the float height [several times] .....a new pump cured the prob and I can only put it down to the old pump delivering insufficent fuel.
hth
T.
2CV6 Special [Red]
C4 VTR+ Coupe [Black]
November 10th, 2012, 11:47 am
hth
T.
+1. Much better since replacing pump.
November 10th, 2012, 1:00 pm
Picked up the van from Richard Daltons this morning - done a good job on it for not that much brass, thank you!
November 10th, 2012, 4:32 pm
Stripped a spare ami engine, I picked it up a couple of years ago after it had been left in a shed for 12ish years, it's full of muck :(
November 10th, 2012, 7:15 pm
.....then filled it with my Bass gear and PA and drove it to Stoke for a gig - cornering still a handful when loaded but not quite as bad as before and manages about 80kph
November 11th, 2012, 3:19 am
Got the engine and 'box out of the beige Dyane. Gearbox is now on the bench with one brake drum off and the rear adjuster removed. The bolt head wasn't half chewed up, and no wonder because it was a bugger to shift even with a pair of mole grips on the snail cam. :lol: Off to ECAS next for new adjuster "bolts" and snail cams.
November 11th, 2012, 5:54 pm
The Acadiane earned it's keep today, transferring stuff from the garage to the lockup storage container I've rented.
Perfect for the job although I may have overdone the 400kg load on a few runs :o
November 11th, 2012, 7:34 pm
drove to the un official meeting on mudiford quay very nice
http://www.mudefordmeet.co.uk/
November 11th, 2012, 9:49 pm
So yours is the 400 with square lights that was in the car park there?
Overly Ambitious Project
November 11th, 2012, 11:58 pm
If it was multi coloured then yes......
November 12th, 2012, 12:08 am
