View unanswered posts | View active topics It is currently August 14th, 2025, 8:07 pm
Reply to topic  [ 538 posts ]  Go to page Previous  1 ... 25, 26, 27, 28, 29, 30, 31 ... 54  Next
 Joolz's Red One
Post Re: Joolz's Red One
Sean,
there's also the possibility (or should that be probablity?) of the plunging splines locking up under very high torque, which is a weakness of the design.
July 5th, 2012, 11:34 am
Hi Joolz
Been looking back through the pictures u have taken, but cant find any of the top of gear stick thingy!! was looking to c how u have sorted ya gear linkage?
Was looking at using the same sort of linkage/fitting that u have used on the track rod end!!
Dyane 12 1976 (ish)
July 13th, 2012, 9:31 pm
Hi Matt, the gear stick 'thingy' on my car is LNA type, so wider than the GS/A and with a rubber bush. It's been changed a couple of times for the different boxes, and the lower bits are just left overs that I haven't cut off.
When I first put the box in I made up a simple extension bracket which bolted to the gear selector lever and allowed me to use the standard change mechanism.
July 15th, 2012, 3:08 pm
Cheers for the photos joolz..
So you have a floor mounted change then??
Dyane 12 1976 (ish)
July 15th, 2012, 4:10 pm
No, but it does come through the bulkhead below the parcel shelf.
July 15th, 2012, 5:34 pm
So have you retained the original position of the gear stick then or changed that aswell...
Got any pics of that Part aswell, (not that I am trying to pinch any off ya ideas like) ;)
Dyane 12 1976 (ish)
July 15th, 2012, 7:06 pm
The gear knob is still in about the original position, but the mechanism is all a one-off. I've not got a picture of it at the moment except this teaser by Pete Mcflurry of this forum.
http://www.flickr.com/photos/squareofth ... 4079762854
July 15th, 2012, 7:19 pm
That is such a teaser :)
Does it work well??
Looks a nice bit of fab just from the small details I can see, Pissed about missing register day even more now, wanted to put some names to some cars/faces etc
Dyane 12 1976 (ish)
July 15th, 2012, 8:26 pm
Here's a pic I took at Giel:
July 15th, 2012, 9:03 pm
Now that does look very tasty...
Dyane 12 1976 (ish)
July 15th, 2012, 9:28 pm
Users browsing this forum: No registered users and 21 guests
