View unanswered posts | View active topics It is currently November 21st, 2025, 12:12 am
Reply to topic  [ 25 posts ]  Go to page Previous  1, 2, 3  Next
 Van Insulation
Post Re: Van Insulation
My brother used that stuff in his house extension. It is expensive, but very flexible. The blurb says it has the equivalent insulation properties as 50mm traditional rockwool/fibreglass.
John Jordan
June 28th, 2012, 3:44 pm
Glue is never going to be an issue, my son works for Bostik. Its a balance between finding something with the right insulation properties, flexible enough to fit all the curves but looks reasonable too.
As I am taking the body off this winter for some serious attention, I can do all of this with the body upside down which has got to help.
June 28th, 2012, 3:53 pm
This with some foam over the top, maybe carry matts will give really good results.
http://www.caraudiodirect.co.uk/chp-alu ... g-mat.html
June 28th, 2012, 3:57 pm
Whilst that may well stop me disturbing the peace while playing Led Zep at full tilt, not sure it will keep 45C sunshine from cooking the occupants of the van though :D
June 28th, 2012, 4:03 pm
Smiffy wrote:
Here's some more info about Triso super 10 properties
June 28th, 2012, 4:10 pm
I doesn't matter how much insulation you stick inside the van, it will still be warm. The trick is to get rid of the warm air letting air through. The blue van is from The Netherlands not made by me.
All sort of things has been tried down under (50 dg in the outback) Ventilation is your friend.
June 28th, 2012, 5:13 pm
I am working on doing both. Expecting the Sahara to be hot in August.
June 28th, 2012, 5:20 pm
I have seen some Landrovers with an extra "double roof".
They use them in the desert
June 28th, 2012, 7:05 pm
Oh yeah... like this
(swiped from Ernst van Altena's book)
June 28th, 2012, 7:13 pm
The Vent in the Grey Van is my AZU250, it works really well in the hot weather and keep the driver's cab cool. They are from an early Toyota Landcruiser if you can find one at a wrecking yard. Cut the whole panel out and cut and weld it in.
Cheers from OZ, Geoff
Melbourne Australia
1968 2cv AZU
1949 Solex 45cc
1956 Solex 660
1959 Solex 1700
1962 Solex 2200
2x 1968 3800's
June 29th, 2012, 5:37 am
