View unanswered posts | View active topics It is currently June 19th, 2026, 7:10 pm
Reply to topic  [ 1048 posts ]  Go to page Previous  1 ... 12, 13, 14, 15, 16, 17, 18 ... 105  Next
 Make Your Own ....2CV.... 4x4
subarupete wrote:
This week - Floors and Sills.
Plenty of room to the left for all the clutch pedal you could ever want, maybe need with the 5 or so gear boxes you have? :lol: :P
June 17th, 2012, 5:25 pm
Are you going to use 2 steeringwheels now...... :lol: :lol: :lol: :lol:
June 17th, 2012, 6:40 pm
Chain drive, need to keep the weight down ;)
June 18th, 2012, 12:24 pm
Seat Mounting.
Planning to use the bottom part of a 2CV seat to mount the home-made seat.
Floor and Sill Patch and De-Channeling.
Body sits 25mm above chassis, used part of a builders plank.
June 21st, 2012, 6:24 pm
Seat Problems...
The clearance between the door catch and the seat is zero.
Cant make the seat any smaller, (my hips) and needs to be positioned so that the gearbox with cover have sufficient space.
Had a brainwave, to widen the cars shoulders.
With my trusty jack have added 75mm
Gives about 30mm extra by the door catch.
June 23rd, 2012, 6:59 pm
Genius. Weight loss would of been easier? ;) ;)
June 23rd, 2012, 7:00 pm
Weight loss won't make your hips any smaller unless you have osteoporosis :)
John Jordan
June 23rd, 2012, 7:07 pm
June 23rd, 2012, 7:53 pm
Alu roof then....
June 23rd, 2012, 8:06 pm
Couldn't you have cut the catch off, then welded the hinge from you other shell to the front of your rear hinge to make it suicide doors?
Anyway, cool solution as ever! :lol:
June 23rd, 2012, 9:50 pm
