View unanswered posts | View active topics It is currently November 20th, 2025, 11:54 pm
 6v electrics.
Post 6v electrics.
Is it possible to use some sort of new technology to make the 6v electrics a bit more modern and safe on todays roads? my main issue is with the indicators as they're pretty hard to see, espescially in the daylight and sunshine.
I'm wondering if there's any sort of electronics that'll work on 6v with LED bulbs that I can make flash, and simply wire into the cars electrics. Is that a simple circuit to wire up, can kits be bought for that kind of thing?
March 13th, 2012, 9:46 pm
Post Re: 6v electrics.
There must be 6v led's and flasher things surely?
March 13th, 2012, 9:49 pm
Yeah of course, most LEDs run lower than 12 volts anyway, and flasher units to run such a thing should be easy to come by, have a look on maplins.
March 13th, 2012, 10:06 pm
You could also run them off relays and an auxiliary 12V battery, I believe.
March 13th, 2012, 10:09 pm
In that case won't you have to upgrade the wires too?
March 13th, 2012, 10:14 pm
Depends on the existing wires & the current flowing through those wires, if LED bulbs are used then I would have said that due to the very low current, it'll be reet.
March 13th, 2012, 10:20 pm
You could ram it full of these, shit little LEDs.
http://www.phenoptix.com/index.php/cata ... sult/?q=6v
Use some of those 6V bulbs.
http://www.superbrightleds.com/cgi-bin/ ... _bulbs.htm
And use one of these flasher units.
http://www.autoelectricsupplies.co.uk/product_list/35
I'll see if we use any that operate at around 6V 'cause some of the LEDs are super blinding.
March 13th, 2012, 10:24 pm
Yeah yeah s'reet I was meaning about if you put another 12v battery in it.
March 13th, 2012, 10:37 pm
Russell,
6 volt flasher relay, 2 x 18-23 watts, item WRE03
http://www.vehicle-wiring-products.eu/V ... ashers.php
6 volt 21watt bulbs, item 317
http://www.vehicle-wiring-products.eu/V ... /bulbs.php
Might need different bulbs, depending on which sockets are already fitted to the mighty beast. ;)
March 13th, 2012, 11:11 pm
Thanks, I thought I'd have to wire up some circuit board or something.
March 13th, 2012, 11:24 pm
Users browsing this forum: Google [Bot] and 15 guests
