View unanswered posts | View active topics It is currently June 26th, 2025, 4:55 am
Reply to topic  [ 337 posts ]  Go to page Previous  1 ... 10, 11, 12, 13, 14, 15, 16 ... 34  Next
 My new 2CV, running restoration. In theory..
Post Re: My new 2CV, running restoration. In theory..
after it blew open on the motorway :shock:
September 26th, 2011, 10:19 pm
panelbeaterpeter wrote:
PROGRESS!!! :o
We have a chassis.
Saw it on eBay, thought it looked good but was outbid by £6 in the last 2 seconds!
Luckily the winning sniper couldn't figure out how to pick it up, so I was told I could have it. It's a very good quality standard type chassis, looks better than Citroen to me, but who knows, can't see any markings on it. It was found in the old 2CV Shitty premises in Halifax by a chap who was clearing it out. Thankfully it's not one of their attempts.
I left Stirling at 3:00pm yesterday afternoon, and got there for 8:00pm. Loaded it up (down?)
Left Halifax at 9:00pm, got home at 4:00 am this morning... :shock: Got 3 hours sleep last night.
Paid £226, the guy also threw in a new set of front door glass and new window catches, and donated a ratchet strap for securing porpoises. Nice chap, had an Acadiane.
It is very very sound, no rust at all, just plenty of Waxoyl. I'll be getting it down to bare metal, repainting it and then drowning it in clear wax, the black stuff always makes things look bodged. Busy with car shows for the next couple of weekends, but should get on it after that, so keep em peeled.
Ah so thats where it ended up!!! I won the chassis on ebay but it was gonna cost me more than the price to ship it down to me so opted for another route with a more local solution.
September 27th, 2011, 10:15 am
ken wrote:
I've driven a 1950s 2CV about 30 miles each year for MOT and was so worried about the doors blowing open that I used to have a couple of luggage straps hooked between them...
Chicken; mind you, mum once nearly got pulled out of the car when she opened the door whilst "making progress". Given she believes a 2CV should always be driven with your foot flat to the floor it got quite interesting. I can still remember the occasion 40 odd years later. She backed out of the throttle to regain control so it was clearly serious.
The same car also gave her a scar on her eyebrow when the side window got her. After that it got traded for a non suicide door car.
September 27th, 2011, 12:27 pm
ken wrote:
pbpeter,
seems that someone from 'a land down under' is working on the same alteration to his 2CV.
< http://snail.s4.bizhat.com/viewtopic.ph ... orum=snail >
Not quite sure what Harley means by a bear claw catch, but if it's something which is going to hold the front doors closed better than the original 'cupboard door' catches, I reckon it's a darn good idea.
If they do let go, they make quite a mess, especially if it's on a van. :(
Thanks Ken, and don't worry folks I am going to use the original (bear claw) handle and catch mechanism, all be it with significant alteration. I saw pictures of the old style latch, reminded me of 50's VW's, not the most sophistimacated of designs. If I'm not convinced it is strong enough to keep my gf safe at 60 mph then I'll fit some kind of extra catch.
September 28th, 2011, 10:44 pm
Aha! shame you missed out, it's a goodun.
September 28th, 2011, 10:46 pm
Yes prob better than the one I ended up with!! :roll:
but needed to get car back on the road quickly so ended up swapping it out with another one all in one day!
October 10th, 2011, 3:25 pm
just like me then :D
PBP i am going to pack the bootlid up this week, and see my friend about getting the door i want to keep repaired so i can get the other door of the car and up to you, it may take a week or two but im on the case mate :)
October 10th, 2011, 11:41 pm
Well I've updated this for a while, mainly due to there not being much going on, I've got the suicide door finished on the other side, and been pissing about figuring out the handle and latch shenanigans.
Decided to use the old locks latches and catches etc, all be it in a chopped up form.
Started by cutting the latch assembly mount area out of the N/S door to use on the O/S, and plating over the hole.
Hung the door and figured where the latch needed to go, and marked it out. Annoyingly it landed exactly where the old hinge was mounted, so I had to redesign the area to mount the latch and handle assembly.
Mounted the striker on the A post
And after a few measurements and messing around, fitted the latch to the door.
Due the the fact that I had to avoid fouling the dash, the handle is slightly lower than the rear, which I'm not happy about but it's a bit late to go back and redesign. Also because the latch was at an angle to match the striker, the handle was at an angle..
Needed sorting as it looked stupid, so I filed out the locating lugs from the inside of the handle
Drilled and tapped holes in the underside of the handle
Figured out what angle the barrel needed to sit at, marked it and drilled a couple on indents to line up with the holes in the handle (Slipped on the one nearest the camera >_< )
Replaced the barrel in the handle and secured it in place with a couple of stainless grub screws. Used Locktite so they shouldn't go anywhere.
Bobs your real dad
Tried it about 20 times and seems strong enough, I guess time will tell.
I then fiddled about with making an interior latch release, using the original handle mechanism.
Firstly the lever on inside of the latch was at the wrong angle to be pulled in a more upwards direction, so I cut the end off it and welded it 45 degrees round.
Mocked the lever mech' up and figured where the handle needed to go, so cut the new pivot and handle holes
Shortened the old latch release bar and put a blob of weld on the end to hold the little washer in place.
Fitted the handle mechanism and it worked to an extent, but needed about 10mm more leverage to open the catch, so I cut and bent the lever to give more leverage
That sorted it, now works very well. Needs a bit of tidying and I need to strengthen the pivot point, but the tricky bit is done, and I have a reference point for doing the other side which will make it alot easier.
That's all folks..
October 19th, 2011, 12:25 am
Woha.....the time and effort you put into this.... And the great results! Respect 8-)
Vennlig hilsen, Eirik
And a Heinemann Z412 -80
October 19th, 2011, 12:48 am
+1,
Mind you, I'd still opt for a safety catch on that ejector lever on the door... :lol:
(Wondering if a rear door catch would fit, then it could be locked? )
Ken
October 19th, 2011, 1:05 am
