View unanswered posts | View active topics It is currently November 20th, 2025, 1:24 am
 clutch slip
Post clutch slip
I have a 1987 D*lly which suffers from clutch slip but not all the time.It varies from a perfect clutch to a clutch that slips like crazy then back to a perfect clutch all on the same journey.The clutch is adjusted properly and the cable action is smooth and light.Having looked up into the bellhousing I can't see any signs of contamination and the clutch dust is dry.I know I will probably have to remove the engine and replace the clutch but just on the off chance that there is a simple and easily fixed reason for this behaviour I thought I'd ask the forum for your opinions.
Cheers Andy
Life begins at the end of your comfort zone
May 23rd, 2011, 2:58 am
Post Re: clutch slip
It may be worth checking the cable is nice and free. If periodically it fails to fully return the clutch would slip. Cables do fray internally.
May 23rd, 2011, 3:04 am
You need 10-15mm free play on the pedal
May 23rd, 2011, 9:44 am
As 250 says, a frayed cable can sometimes give intermittent stickiness, seemingly behaving ok for most of the time.
My old kit car used to love sticking the accelerator pedal open on full throttle once every couple of weeks. What that did for my middle-aged-racer credentials doesn't bear repeating - flooring her away from the lights followed by a massive scream of over-revving Pinto as the clutch was dipped for second gear - with the throttle remaining wide open... :oops: I'd originally dismissed the cable as being guilty as it appeared smooth enough when tested by hand. But, frayed it was.
May 23rd, 2011, 1:35 pm
Sorry James,
but Citroen specify 20 to 25mm free play... ;)
May 23rd, 2011, 1:51 pm
Thanks for your thoughts guys, will try replacing the cable first.(fingers crossed)
May 23rd, 2011, 1:56 pm
ken wrote:
Sorry James,
Bastard
But thank you for correcting me. I've learnt something today ;)
May 23rd, 2011, 10:59 pm
lovin' the snatch
i really wouldn't be calling someone that you want as your best friend a "bastard" ...
|-|-' 602 For Life :)
Keep Them Looking Standard.
1979 Myosotis Blue Dyane6
1986 Sunrise Red 2cv6
May 24th, 2011, 12:52 am
Yep,
James forgot the "old" bit, which was slightly disconcerting... :lol:
May 24th, 2011, 12:59 am
All my friends call me 'bastard'... :(
May 24th, 2011, 1:18 am
