View unanswered posts | View active topics It is currently May 1st, 2026, 8:35 pm
 6 volt help!
Post 6 volt help!
6 volts have never been my strongest side. This 6 volt indicator does not work. The 2cv has 1 only indicator mounted on the body side near the rear triangle window showing forward and rear warning. The lights (both sides) comes on but no flashing.
This thing has 7.19 volts going in when the engine is running but 6.20 volts feeding the indicator switch. The ‘’klak klak’’ is not working either but lights are passing across when bridging. I looked at a new indicator but it has 12 volt not 6 volts written on it. What to do? Help is appreciated.
Viking
May 17th, 2011, 4:39 pm
Post Re: 6 volt help!
Not entirley sure what your asking?
substitute a modern clacker less indicator switch in to the system (wont matter its 12v as its just contacts) - if the indicators all work as they should then its the 12v clacker thats causing the problem in your 6v system
if they still dont work then look at the relay and earths etc
May 17th, 2011, 4:45 pm
Swapping between the original 6 volt fitted and new 12 volts makes no difference. The rely or whatever it is has no earth only feed in and feed out.
The help I'm looking for is:
What is the rely doing and how to test it
Is the klak klak depending on 6 or 12 volt. In other words can a 12 volt be fitted and still work?
May 17th, 2011, 4:59 pm
Managed to remove the cover. It is a flasher rely but it is not working. I can manipulate the contact points with my finger and the 12 volt klak klak switch beings working. I guess the search begins for a new 6 volt rely but where? Haven’t seen any around, any ideas?
May 17th, 2011, 6:27 pm
there is usually a resistor wire ans a spring the wire carries the currrent heats expands pops the spring cools spring opens and the circut is made again.
try ajusting the screw stop at the RHS of that picture
May 17th, 2011, 7:58 pm
I'd think it'd have to be one specifically for 2cv - because of the lower resistance from the single bulbs. Most generic 6v relays will be expecting two bulbs, and only a single might cause it not to flash, same as if one bulb's blown.
May 17th, 2011, 8:39 pm
Good thinking, that will narrow down the search.
May 17th, 2011, 8:54 pm
http://cgi.ebay.fr/CENTRALE-CLIGNOTANTE ... 27bafe1dfd
May 17th, 2011, 9:18 pm
twofifty AZU wrote:
http://cgi.ebay.fr/CENTRALE-CLIGNOTANTE-2CV-6-VOLTS-/170640940541?pt=LH_DefaultDomain_71&hash=item27bafe1dfd
Yes the same but does it work. Will give it a go. Thanks
May 17th, 2011, 9:43 pm
No take the 12v clacker out of the equasion by putting in a clacker less indicator stalk-a modern one with no clacker
then if the relay still doesnt work ajust the screw that sets the wire tension,
still no joy - then get a new relay
May 17th, 2011, 9:57 pm
Users browsing this forum: No registered users and 86 guests
