View unanswered posts | View active topics It is currently April 30th, 2026, 5:46 am
 Identify a gearbox?
Post Identify a gearbox?
Hi all,
Does anyone know if it is possible to know if a gearbox is Dyane or 2cv based on its outward appearances?
I've had this one around for years, I suspect it is from a Dyane, but can that be told without taking it apart and counting the teeth?
Underneath about 1cm of historic crud on the lid I found these strange markings...
Any ideas? Thanks in advance!
February 26th, 2011, 2:21 am
lovin' the snatch
Post Re: Identify a gearbox?
am i right in thinking the dyane boxes had longer or shorter input shafts than 2cv boxes? i know its all todo with splines and lenth of shaft due to the dyane's mostly having the older 3 finger clutch rather than the diafragm clutch which wasnt fitted till 82' according to cats! i didnt realise the dyanes actually had the later clutch, did they come with a lighter flywheel aswell on the very last models?
|-|-' 602 For Life :)
Keep Them Looking Standard.
1979 Myosotis Blue Dyane6
1986 Sunrise Red 2cv6
February 26th, 2011, 3:13 am
A closer shot of the input shaft would help.
If there's a single ring engraved on that smooth section just forward of the splines, it's a Dyane box.
No ring(s), it's got 2CV gearing and with 2 rings it's a 2CV4 box... ;)
February 26th, 2011, 3:19 am
Wow where else could you get such advice at 1am? Thanks!
I'll get a better shot of the input shaft and let you know.
February 26th, 2011, 3:22 am
guessing that Kens guests ETA of 11 pm had been extended !
February 26th, 2011, 9:07 am
Or you could use the Jeroen Cats method:
http://www.cats-citroen.net/citroen_aty ... ition.html
February 26th, 2011, 12:48 pm
Nope,
he arrived on time, guess keeping to the travel schedule was connected with having the family along. ;)
February 26th, 2011, 1:02 pm
So I guess My suspicions were correct then - Dyane?
It looks like one engraved ring.
March 6th, 2011, 1:40 am
lovin' the snatch
sorry to hijack
but can the older style gearboxes be used with a newer engine? for eg one which would have been on a car with a 3 finger clutch and heavy flywheel, and fitting that onto a car with a light flywheel and diaphragm clutch?
March 6th, 2011, 1:44 am
You can Joe,
But its not ideal, the splined part of the shaft doesn't go all the way down the boss in the middle of the clutch.
Plenty of the earlier racers didnt come to any harm and the Dyane box that's in my 2cv has been ok for the last 9 yrs
changing input shaft is a bit of a chore as it means taking the box pretty much down to its component parts.
sean
March 6th, 2011, 12:16 pm
