View unanswered posts | View active topics It is currently August 14th, 2025, 10:05 am
 Odin
Post Re: Odin
Finished all 4 swing arm bearings, cleaned and greased up. Fitted both spring pots and connected all tie rods, end eyes and knife edges. Clips secured with wire so I won't loose them on the raid if going through high grass or bushes.
November 3rd, 2010, 10:11 pm
Post Re: Odin
Moving on to the steering
Track rod end housing and steering arm ball joints dry as bone + some minor chips to file away. Cleaned, greased and fitted again with new boots.
November 3rd, 2010, 10:30 pm
Post Re: Odin
Last job today was stripping the steering rack for a good clean and regreasing.
Pinion bearing buggered.
Guide ring a bit worn.
November 3rd, 2010, 10:38 pm
Post Re: Odin
Finished the rack today. When time comes, I'll do a proper steering rack over haul. This will do for now
Removing the guide ring manily due to too much play between the ring and the guide. New ring is fitted tested inside the guide making sure it does not bite on the guide moving it from side to side
Securing the guide ring with a rivet
Sorry not photo of fitting and adjusting the ball joints, next time
The new reproduction pinion is too big and is biting when fitted in it seat.
November 7th, 2010, 7:39 pm
Post Re: Odin
Body work, gives me a break from the mechanics
Not much need for text here, photos says it all.
Would like to ask is the rear cross box is available. If yes, great, please PM a price to France + postage.
Cheers Viking
November 7th, 2010, 7:46 pm
Post Re: Odin
How come everything (except for the obvious greasy bits) looks so clean? Stuff don't 'alf look tidy in the pictures.
November 7th, 2010, 7:50 pm
Post Re: Odin
Sorry I don't understand your question :oops:
November 7th, 2010, 7:57 pm
Post Re: Odin
Not so much a question as an observation, sorry! It all looks so clean (even some of the stuff you are replacing)! Everything on my cars have been covered in cack and dirt! The photos above just look so shiney! Very nice :)
November 7th, 2010, 8:01 pm
Post Re: Odin
Oh I see. No no everything is very dirty, just cleaning a bit before putting everything back together. Sometimes I clean before stripping as I can't see a bloody thing.
November 7th, 2010, 8:17 pm
Post Re: Odin
Cheers Viking
Do you mean this panel Peter.
http://www.renov-2cv-mehari36.com/carro ... diane.html
November 7th, 2010, 8:55 pm
