View unanswered posts | View active topics It is currently July 1st, 2025, 10:16 am
Reply to topic  [ 89 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9
 Blue Smoke / Engine flush?
Post Re: Blue Smoke / Engine flush?
There's a hole (which others have described) in the engine casting, which lines up with the one you found in the flywheel when the flywheel's at the right point.
The reason Haynes says to connect the test light between the points wire and earth, is because their idea of a test light is a bulb connected in series with a torch battery. The way Sean's described is easier though, and you don't need to find a battery!
October 20th, 2010, 10:38 am
Oh right ok, understand about lamo and found hoke. Will post pic tonight!
October 20th, 2010, 12:34 pm
Also why noy one wire on battery pos then earth it on points, then no ignition needed, at all surely?
October 20th, 2010, 12:57 pm
STOP IT
:lol:
October 20th, 2010, 2:16 pm
Sean wrote:
STOP IT
:lol:
I just died a little bit inside.
October 20th, 2010, 2:17 pm
Sean wrote:
however R-T connecting an earth to the points(earth) via a bulb wont do anything you can do that with the multimeter on continuity and buzzer but not lightbulb
you need the iggy on and bulb in place of the coil between the 2 leads.
Works for me, and always has. One end of my test lamp wedged in the alternator bracket, t'other end clipped to the points to coil lead. The light goes on and off as the points open and close.
October 20th, 2010, 4:03 pm
cool :) whatever works
its been 20 yrs since i did it with a bulb :lol:
October 20th, 2010, 4:12 pm
Sean wrote:
no take both leads off the coil and put bulb between them
or multimeter?
really sorry about the kuffuling, when you said put them between them i thought you meant on the coil, not on the ends of the wires, i may go straight from battery to save faffing, off to do timing now! wish me luck :roll:
October 23rd, 2010, 6:29 pm
right poitns done, now just to do timing, wasnt certrain on whether the light should be out at firing point or not, so re read it understood if and off i go again
October 23rd, 2010, 7:32 pm
