View unanswered posts | View active topics It is currently August 14th, 2025, 11:04 pm
Reply to topic  [ 425 posts ]  Go to page Previous  1 ... 20, 21, 22, 23, 24, 25, 26 ... 43  Next
 Spa 2010
Post Re: Spa 2010
I think the heated toilet would be brilliant, but I really can't see a way to do it easily. 12v elements are way to lame, I've seen how long it takes to heat one cup of water. A 240v element liberated from the bottom of a kettle would be quicker but would need a generator and health and safety might be an issue.(This idea's gained some support since I started typing).
If there's a bonfire nearby it would seem a real shame not to utilise it in some way, I spent a while trying to think of a system to pump hot water between the toilet and a boiler, ideally you'd need to heat the bowl and the cistern but it's just too much work. Dropping hot rocks into the bowl is easy but I dunno how effective, they might shatter and you'll get ash in the wine.
I don't like to admit defeat but the options look like cold mulled wine (not an option), or heat it in a pan/cauldron.
September 26th, 2010, 11:27 am
Post Re: Spa 2010
I'm just scoping eBay for things that might be able to do what we're after. Portable 230v immersion heaters are about a tenner, and we could get a genny for about a ton. Because I understand nothing about electricity, what would happen if we plugged a 2000w heater into a 300w 12v-230v inverter?
September 26th, 2010, 11:29 am
Post Re: Spa 2010
It would probably just trip out, inverters are pretty rubbish at providing high wattages. The cheap ones can only manage a couple of hundred watts.
September 26th, 2010, 11:33 am
Post Re: Spa 2010
I did wonder if it would result in a failure of the inverter. Would it also herald the end for a genny too? Or would it just put a lot of strain on it?
September 26th, 2010, 11:35 am
Post Re: Spa 2010
I would think any modern generator would have some sort of overload protection, so it would just trip off as soon as it was connected. Most of the generators on ebay are cheap chinese crap, and are massively optimistic about their capacities, I reckon you'd need one rated at 3500watts to comfortably run a 2000w immersion element.
September 26th, 2010, 11:47 am
Post Re: Spa 2010
Ikea sell glogg which is available all year round - its non alcoholic tho
September 26th, 2010, 2:04 pm
Post Re: Spa 2010
Russ,
how about one of these, or even a couple of them?
< http://cgi.ebay.co.uk/ELECTROLUX-DOMETI ... _720wt_930 >
Your battery and alternator will both need to be in gwo, I'd guess... ;)
September 26th, 2010, 3:35 pm
Post Re: Spa 2010
ken wrote:
Russ,
I might have a cheeky bid on that!
September 26th, 2010, 3:40 pm
Post Re: Spa 2010
Here's another one to keep you busy... ;)
September 26th, 2010, 3:45 pm
Post Re: Spa 2010
aye, i'm guessing that's a fairly big draw on the battery with that, and the high-powered 8 track transmitting up tempo muzak.
September 26th, 2010, 4:15 pm
