View unanswered posts | View active topics It is currently May 1st, 2026, 10:57 am
Reply to topic  [ 57 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
 Spare wheel or not?
Post Re: Spare wheel or not?
I've just put a subwoofer (10kg) in the boot and the car has changed its stance. There is more on the back wheels. I tend to like weight on the front wheels, better turn-in etc.
Seems silly to have all the lumber in the boot when I have never had a puncture.. ever.
Shame they dont make a space saver spare for the 2CV!
Many new cars are not supplied with spares, or even anywhere to put them.
Charlie is gone. Now 2CVless.
September 6th, 2010, 1:32 pm
You're talking about a 125 or 135 section tyre here, it IS a space saver tyre ;) Also, never ever say "ever", you're tempting fate :lol:
September 6th, 2010, 3:11 pm
yes 125s all round, space saver but not weight i suppose. Well am ok with tempting fate at the moment as the wheel is still under the subwffr
September 6th, 2010, 3:54 pm
This could be a working solution without cutting a hole in the bonnet. My C4 Picasso has no spare wheel at all not even a skinny one.
http://www.tpv-2cv.fr/tpv_panier/fiche_ ... ?ref=19029
September 6th, 2010, 4:23 pm
This might display better
September 6th, 2010, 4:31 pm
Are you sure that'll work?
Theres more heater ducting on a R/H Drive 2CV.....plus a washer bottle,headlight hieght adjuster bar and the brake fluid res.
I'm not saying it wont work,but it could be more trouble than its worth.
btw,pic is my own 1988 spesh ....ignore the alarm and bulkhead mounted volt regulator.
T.
2CV6 Special [Red]
C4 VTR+ Coupe [Black]
September 6th, 2010, 4:48 pm
Good point, I forgot about cars built the wrong way around. :oops:
September 6th, 2010, 5:15 pm
under bonnet spare wheel carriers dont fit on rhd cars
September 6th, 2010, 6:15 pm
they do but you have to move stuff around
September 6th, 2010, 6:26 pm
That tyre repair foam stuff is fine as long as the tire only has a small puncture which could otherwise be repaired, once you've launched that stuff in it prevents any repair patch from properly vulcanising. Any tyre repair place worth it's salt will know that and refuse to repair it. If then do repair it in most cases the patch will come adrift. So you've spent a fiver on a temporary fix and then £100 buying a new tyre. If you just whack a spare on you give your local tyre fitter a fiver and he'll mend the flat tyre. In a blowout you're cattle-trucked either way and the can of foam will be about as much use as an ashtray on a motorcycle.
If the cars sitting too low now it's for a sub in it, just wind the tie rods in a few turns.
You can adapt the lhd underbonnet spare wheel holders to fit rhd cars or quite simply make one yourself.
A ten kilo sub will make virtually bugger all difference to the handling. It was designed to take a ton of shit and some goats to Market, along with the farmer, his mrs and all thier clobber, so I doubt it'll make any odds to how the car drives, if it does it's probably more psychological!
September 6th, 2010, 7:36 pm
