JRW_91
lovin' the snatch
Joined: January 27th, 2009, 8:10 pm Posts: 1289 Location: Northampton
 Tappy problem...
right, i fitted the cylinder heads off my old dyane engine (AM2) yesterday, keeping it complete with the pushrods aswell from that engine. Fitted them both with new spectacle oil seals, new manifold gaskets inlet and outlet and new rocker cover gaskets. i adjusted the valve clearances to (0.20mm inlet and 0.25mm outlet) as per Ken's instructions, just like on the old cylinder heads... except now im being deafened by the sound of extremely excited tappets.... i dont know whether its the heads, or whether i've done something wrong, but the tapping is extremely loud and i dont know what else todo, i've checked the clearances and they are all fine, i thought dyane/2cv cylinder heads were the same, or are the pushrods different lengths to 2cv ones? any advice would be greatly appreciated, thanks, joe
 |-|-' 602 For Life
Keep Them Looking Standard.
1979 Myosotis Blue Dyane6 1986 Sunrise Red 2cv6 1989 Vert Bamboo 2cv6 D*lly (in bits)
| July 30th, 2010, 4:08 pm |
toomany2cvs
 Re: Tappy problem...
Gay_Joe wrote: i adjusted the valve clearances to (0.20 inlet and 0.25 outlet) as per Ken's instructions, just like on the old cylinder heads... 0.2-0.25mm? Absolutely sure they're metric feelers? Because if you've got a set of imperial feelers and you've set 'em to 20 thou, that's 0.5mm...
| July 30th, 2010, 4:22 pm |
Lenny
How tight did you do the rocker cover nut?
| July 30th, 2010, 4:23 pm |
JRW_91
lovin' the snatch
yeah my feeler gauge is in mm and we havent got a torque wrench at the moment, so i did them finger tight and then half a turn with the ratchet.
 |-|-' 602 For Life
| July 30th, 2010, 4:34 pm |
2CViking
I've seen push rods fitted the wrong way around or maybe loose push rod heads
| July 30th, 2010, 5:45 pm |
toomany2cvs
Gay_Joe wrote: so i did them finger tight and then half a turn with the ratchet. 180deg? Any sign of impact on the inside of the cover? Do they sound the same when fired up (briefly) with the cover removed?
| July 30th, 2010, 5:48 pm |
JRW_91
lovin' the snatch
i made sure that the rods stayed in each tube as they came off the dyane engine, and before they went onto my engine Viking, also the rods we're seated into the rocker arms nicely, could it really be something as simple as i've over tightened the rockers? surely if they were any looser they'd start spaffing oil everywhere?
Adrian, we must have been typing at the same time!! i didnt see anything earlier although the rockers had oil in them, and i didnt try starting without the covers on!
but yes, i finger-tightened the rocker cover nuts, then it was 180 with the ratchet!
 |-|-' 602 For Life
| July 30th, 2010, 5:52 pm |
Gay_Joe wrote: yeah my feeler gauge is in mm and we havent got a torque wrench at the moment, so i did them finger tight and then half a turn with the ratchet. are the bottom "peg" bolts on the rocker shaft tight? no point in checking the torque on the heads till you get hold of a torque wrench (you can "guesstimate" but un less your used to it its not worth advising it) also if you over do the rocker cover nut you can have the tappets contact the cover Sean
| July 30th, 2010, 5:53 pm |
Joe it might be worth getting the terminology right as its a bit confusing as to what you've done
rockers are the arms that move, the tappet screws are the ajustment on the end and the big jelly moulds that cover it all are the rocker covers.
| July 30th, 2010, 5:56 pm |
2CViking
Any chance of a photo?
| July 30th, 2010, 5:59 pm |
Users browsing this forum: No registered users and 73 guests |
