View unanswered posts | View active topics It is currently August 16th, 2025, 8:32 am
 Gear box story World Meeting
Post Gear box story World Meeting
Sorry in German
http://www.citroenchen.de/2010/02/GetriebeRepFrance.htm
July 21st, 2010, 10:00 am
Post Re: Gear box story World Meeting
This is great to read through Babelfish:
Translated into interesting English
Afterwards it continued to go on heart-all-dearest small white roads, which finds so only my related by marriage navigation system, into normandy to marvelous meadows and forests as well as beaches and chalk rock.
Good Job Viking :D
July 21st, 2010, 1:15 pm
You've gotta love Babelfish! :D
July 21st, 2010, 2:03 pm
Viking,
that input shaft must be the outright winner of the 'disappearing oil return scroll' competition... :lol:
July 21st, 2010, 2:04 pm
Try this one
http://translate.google.co.uk/translate ... =&ie=UTF-8
July 21st, 2010, 2:06 pm
ken wrote:
Viking,
Sorry don't get it Image
July 21st, 2010, 2:10 pm
Viking,
perhaps it's a trick of the light, but the oil return scroll in that picture seems to be worse than the worst of this batch... :?
July 21st, 2010, 2:38 pm
OK now I get it. No no the input shaft is fine, the camera is not picking that up. Wouldn't fit a crappy part unless in the middle of the Australian Outback with no parts available, just to be able to continue
July 21st, 2010, 3:01 pm
ken wrote:
Viking,
For us non-enlighten people is this what you 2 are talking about? So what does it do?
July 21st, 2010, 3:13 pm
Norman,
the 'oil return scroll' is a type of thread formed on the input shaft. As the shaft spins, it moves any oil which is trying to escape out of the gearbox back towards the chamber in which the crown wheel sits.
There's a small drain tube cast into the housing opposite the saw tooth section for this purpose.
The problem is that if the input shaft is out of true ( input shaft bearing shot, centring dowels between engine and gearbox not fitted, etc.) the scroll will be worn away against the inner surface of the steel tube through which it passes.
The general rule is that if the scroll is worn so that the 'valleys' are narrower than the 'crowns' of the threads, then the shaft is scrap, as the chances of oil reaching the clutch plate are increased...
July 21st, 2010, 3:45 pm
