View unanswered posts | View active topics It is currently July 3rd, 2025, 11:57 am
Reply to topic  [ 455 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8 ... 46  Next
 Yet another red spesh...
Post Re: Yet another red spesh...
its good but it needs bullet holes
June 14th, 2010, 8:31 pm
I have no idea how I'm going to buy the floors, sills, bulkhead and rear heels it needs, I have a budget of £buggerall to do this.
Buy at least 4 cans of lager, I'm a real lightwieght and starting at 9am this morning 4 have barely sufficed. BE WARNED. Espescially if you need to drive to get beer, luckily, i was able to walk to the little shop at the end of the road when the first two can's ran out, you might not be so lucky.
Twenty fags have lasted the day, with plenty to spare for tomorrow.
Stop smoking an buying beers isn't an option? :lol:
Could save a few quid ;)
I'm going to have to try and make mine a bit different I think, I don't know how though...
This:
:lol:
Or, with 2 rear ends together ;)
June 14th, 2010, 8:44 pm
Its all good practice, might have to lift the race car body off :roll:
June 14th, 2010, 8:46 pm
I've got the old man to take my Peugeot wheels to work and try on a few different size tyres. Ideally I want a fairly low profile 155 or 165. Blackcircles have 155/65/15s for about £150 a set or 165/65/15s for a bit more. Ideally I'd like to lose between 5mm-10mm off the ride height with them, and have a fairly stiff sidewall. With any luck Dad can bring me home a couple of scrap tyres to try and so I can cut off anything they're going to foul on (or make sure they're not going to foul on anything I can't cut off) before i spend any money on them.
As for the roof, well, there's no way i can justify buying a new roof for it, but there's also no way I can justify using the roof it's got. I think I'm going to have to be creative with that aspect of the car.
I'll have to whip the front arms off it at some point and take them to work to cut/turn them, also, I'd like to have a fair bit of camber on these, so the top of the front tyre is tucked up in the arch. On the Bamboo every time you had it sideways on opposite lock the tyre caught the arch and pulled the wing and headlamp bar off. I'd like this to be a bit more considered and professional than that.
I'm a bit worried about the rear arms. They aren't holed but under all the crud when you squeeze it it feels like it's gone a bit rusty. I'm aiming to have a go at bending them, how exactly do I do this? just make an arm bender, bolt it on and tweak it on the car until it looks about right?
Looks like I might have to get the cage out of the racer shell (it's useless for that anyway) repair it, and fit that too. I'd like to make some extra parts for it (hot rod style chicken bars and a rear 'X' brace)
Simon, what's up with the race car? Is it nothing that can be repaired in situ?
June 14th, 2010, 8:54 pm
perfect. :lol:
June 14th, 2010, 9:10 pm
Russ the rear arms are easy, wheel with an axle stand welded to it, bit of scaffold bar, I have one here, we need to do a couple of arms for the race car in case!
The race car shell where it bolts through the floor (see picture) its not doing anything!
June 14th, 2010, 9:33 pm
Can you get some better photo's Simon? I reckon we could do that in situ. Are you about saturday afternoon?
June 14th, 2010, 9:34 pm
Yep here all day Saturday - I will see what I can do with some pictures in a bit
June 14th, 2010, 9:41 pm
I'll have the welder in the car, I can bring wings and headlamp bar iff you like?
June 14th, 2010, 9:51 pm
Not sure if they are better pictures! took the bolt out and yes you have guessed it - it rolled along the floor, straight into one of the floor holes BUGGER :x
The bits would be great thanks
June 14th, 2010, 9:55 pm
