View unanswered posts | View active topics It is currently April 29th, 2026, 7:33 am
Reply to topic  [ 36 posts ]  Go to page 1, 2, 3, 4  Next
 9:1 in a 2cv any benefits?
Post 9:1 in a 2cv any benefits?
Now my 2cv is almost finished I've had in mind a 'stage 2' which is to rebuild the spare engine lurking in the garage as a 9:1, increase the jetting slightly, fit leccy ignition, and mate it to a refurbished Dyane gearbox that I have. because I'm a fan of the old heavy flywheel (which will be used too) what sort of engine characteristics would this whole set up then give me? I ask because of a comment I've just read saying 9:1 won't make much difference over a good 8:5:1, which mine is.
Can I expect for example a higher cruising speed? lower or higher fuel consumption? Smoother or rougher mid range pick up, that sort of thing.
May 26th, 2010, 2:41 pm
Post Re: 9:1 in a 2cv any benefits?
Hi Mr Nail .....I've got 9:1's and re-jetted carb in my '88 2CV ....[and Luminition EI] .....the 9:1's were added long after the EI,and they do seem to increase the torque and help acceleration,I cant say I've noticed any decrease in fuel consumption [although I do occassionally treat the engine to a tankful of "Super" ...which is of course slightly more expensive than orn'ery unleaded].
Top speed is reached a little quicker and perhaps it gives me a couple of mph "top end" ....but all the extra "top speed" is doing is making the [my] engine work harder.
Hills seem easier with my 9:1's .... I'm not changing down as early.
I guess a Dyane gearbox will give you a few extra mph from the same revs in top [6.5% .... if my calculations are correct thats about 4mph] .... but [fwiu] the Dyane box has an annoying gap between 1st & 2nd ....so for that reason I've opted to stick with the 2CV 'box [for now :| .....plus the fact that quite often these days I'm towing a hefty trailer tent to some 2CV meet or another]
The [your] best option is a Rick Pembro gearbox ...basically its a 2CV bottom end with Dyane top end....not cheap though.
more info here
http://www.gearbox-guru.co.uk/
edit .....btw,I thought I'd got a good 8.5:1 ....until it went "bang" :shock: one day .....and I had the engine rebuilt by Uncle Ken.
hth
T.
2CV6 Special [Red]
C4 VTR+ Coupe [Black]
May 26th, 2010, 3:35 pm
Sounds good to me, very close to my set up. Definatly gives More power and acceleration and doesn't loose speed when you get to the hills which is great :)
Low and Loud!
May 26th, 2010, 3:43 pm
Thanks guys. The two main things I'm looking for are a stronger mid range, allied to a less frenetic 75mph or so. What size jet is best to put in? Also I've never driven a Dyane so I can't picture what that gap is all about, but the gearbox I have is a good 'un so shame to waste it?
May 26th, 2010, 3:45 pm
Old-Nail wrote:
.........I've never driven a Dyane so I can't picture what that gap is all about ...
It means you're changing gear sooner [1st to 2nd] when setting off at junctions,roundabouts etc.
Increases the chances of some numpty behind you banging your pride & joy up the *rse considerably [imho].
Unless of course,you fix a huge towplate & towball [like wot I saw the other day on a dirty looking 4x4 Landie] .....with a sign saying .....
"Your skid stops right just HERE" :shock:
T.
2CV6 Special [Red]
May 26th, 2010, 4:04 pm
That makes sense actually, there has been a few Dyanes bumped up the backside as I recall. I wonder why they did that then? :? I dare say I can't afford one of those Pembro jobs so I'll have to make do with either the 2cv or Dyane boxes that I have.
May 26th, 2010, 4:11 pm
Can't say I ever noticed any difference between 2CVs and Dyanes when accelerating away. They may well have different gear ratios but I wonder how much of the difference people claim to notice is down to having read that there is a difference? ;)
May 26th, 2010, 4:16 pm
Very well said. Most of it is in the mind, the rest in the tuning. :D
May 26th, 2010, 4:21 pm
Acceleration was definitely improved by changing to 9:1, though top speed was reduced for a few weeks before then going back up to about 70.
May 26th, 2010, 5:07 pm
I owned [a number of] Dyanes from 1974 to 2000.
I've also owned my 2CV from 1988 to date.
I cant say I ever noticed a vast difference.....[although I always suspected :? that my 2CV was "quicker off the mark" ]
My mate [Dave Blackett] has both a Dyane & a 2CV .....he claims he notices straight away.
Having towed [the same trailer tents] with my Dyanes & 2CV .....I can confirm that the 2CV is a better car for towing with.
T.
2CV6 Special [Red]
May 26th, 2010, 5:14 pm
Users browsing this forum: No registered users and 72 guests
