View unanswered posts | View active topics It is currently November 20th, 2025, 7:10 am
Reply to topic  [ 41 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 ICE.
Post Re: ICE.
I'm running 6x9s and a sub from my amp but when volume is turned up loud it gets to a point when the 6x9s get distorted from the bass. I've seen Russell said somewhere about bass filters (but can't find it) and i can't find anything on the net that fits inline from amp to speakers, is there another name for these bass filters?
Low and Loud!
April 11th, 2010, 10:59 pm
Post Re: ICE.
Crossovers.
I don't think that's the whole story though, I don't think your 6x9s sound half as good as they would in boxes or in a solid shelf. I'm guessing you have a 4ch amp with a bridged channel for the sub? You should be able to adjust the frequency range of the front or rear channels on the amp. I reckon you should put your 6x9s in boxes, or a shelf then you can set the amp up accordingly. I sat out in the middle of nowhere, turned it up as far as it would go with the gain turned right down, then turned the gain up until the amp just started to clip the sound (distorting). I then did the same for the rear channel that runs my sub. That will leave your system able to run as loud as it can. If it still distorts, then you need to turn the gain down a little, although you might be able to stop it by adjusting the crossovers on the amp so the speakers play a smaller range of frequencies that they can cope with. In line crossovers and bass filters are available, but if you don't have them on your amp, you probably want to think about a better amp. My jbl amp was about £45ish on eBay, well worth that. I'll try and find those speaker boxes for 6x9s I used to have, you'll find yours sounds much better with them ;-)
April 12th, 2010, 7:15 am
gym bunny
Post FW: RE: carbs
I got mine from halfords last time i got any. 1for blockin treble on sub n 2 for blockin bass on speakers. Just frequency blockers as far as i know. Work ok but better to mount speakers properly n adjust levels to suit. I run only bass through the sub. Speakers r without n only 4 volume.
1299cc FTW
April 12th, 2010, 12:23 pm
Post Re: FW: RE: carbs
Same here.
April 12th, 2010, 1:11 pm
Post Re: ICE.
Crossovers.
Your probably right there, they are just cable tied to the roof bar haha!
don't know what channel my amp is, i can run speakers and sub - it's got built in crossover and 1200 amp so i'll try adjusting the levels as per your instructions and see if i can get some better sounds (preping for FN init) 8-)
Low and Loud!
April 12th, 2010, 8:41 pm
Post Re: ICE.
If you come here and change my kingpins I'll fit your speakers and set your amp up. :-p
April 12th, 2010, 8:44 pm
Post Re: ICE.
Saturday??? :P
Low and Loud!
April 12th, 2010, 8:49 pm
Post Re: ICE.
Haha, I was only half serious, I don't have kingpins or the drifts to change them, I might be able to get them by sat if you fancy it? Indian Saturday night on me?
April 12th, 2010, 8:58 pm
Post Re: ICE.
My dads got the drift kit, just get king pins
I need wheel bearings and kingpins and 2 more tyres before france!!
er my head unit is grey ;)
Low and Loud!
April 12th, 2010, 9:03 pm
Post Re: ICE.
Gr8 4 driftn.
I'll dig the boxes out dude, if you're happy with that? It'd be a massive help! If not I'll just stick the standard arms back on.
April 12th, 2010, 9:30 pm
