View unanswered posts | View active topics It is currently April 30th, 2026, 12:15 am
Reply to topic  [ 7 posts ]
 How do I make a non galvanised chassis last longer?
Post How do I make a non galvanised chassis last longer?
It is in very good condition, but not "finished off", what is my best move?
A friend said 'wax oil'
thanks
Charlie is gone. Now 2CVless.
April 2nd, 2010, 8:01 pm
Post Re: How do I make a non galvanised chassis last longer?
yup the black stuff seems better than the tan stuff
thin it with white spirit, and spray it in side the chassis
then paint it on the outside paying particular attention to the seams, could even warm it with a blow lamp to get better flow
if the chassis hasnt been painted paint it first dont go with rattle cans use synthetic enamel ( even household gloss is better than the likes of hammerite)
April 2nd, 2010, 8:14 pm
thanks, the actual underneath has under-seal, but I reckon I can get plenty of wax oil into the inner parts.
April 2nd, 2010, 8:23 pm
When you have a good chassis and it isn't rust protected (also not inside), get all the paint and dirt of, (grinder) or better with chemicals and then........
Galvanise it.
I did my chassis too 10 years ago and it's the best thing I ever did.
good luck.
Please ask the local galvaniser first if he wants do do this, first thing they say the chassis has to be bare metal.
April 2nd, 2010, 9:53 pm
This sounds a crazy idea to me. What make of chassis is it? Stripping, cleaning (the cheapest, easiest and most environmentally friendly way is shotblasting) an old chassis completely to have it dipped in a tank is going to take you longer than fitting a new chassis and not so much less financially. If it's a reputable make it would be best to flood it with a preservative, having removed as much muck and corrosion as possible. If it's a dodgy one, then buy new. Remember a cheapo chassis will strain the body causing more corrosion there - and that's much more difficult to sort out! Let alone never drive properly :!:
If your chassis is by Citroen, then I think it would be pointless trying to galvanise it anyway.
April 3rd, 2010, 11:30 am
I am not 100% sure, but I think my chassis is the original Citroen one.
April 3rd, 2010, 11:45 am
lovin' the snatch
does it have an under tray? under the engine? and the chassis Vin plate should be on the offside front chassis leg, jut below the offside cyinder, has anyone been able to confirm whether it is an aftermarket or original? do you have any piccis?
|-|-' 602 For Life :)
Keep Them Looking Standard.
1979 Myosotis Blue Dyane6
1986 Sunrise Red 2cv6
April 3rd, 2010, 5:04 pm
