View unanswered posts | View active topics It is currently April 30th, 2026, 10:53 am
Reply to topic  [ 3 posts ]
 Genuine Tow Bar Bolts
gym bunny
Post Genuine Tow Bar Bolts
Right, question is, Do i use the existing axel tube bolts or should there be some longer ones avaliable? I ask as the thickness of the towbar reduced the amount of working thread through the axel tube locations?
I may have missed something obvious but please help to put my mind at rest!
cheers!
1299cc FTW
October 28th, 2009, 8:56 pm
Post Re: Genuine Tow Bar Bolts
Tim,
d'you remember that gearbox which donated an output shaft a while back?
Well, you may need to plunder some more off it, as the bolts holding the calipers on are an ideal length for fitting an original Citroen towbar to a chassis.
They're also the correct 10/9 grade, so should prevent your axle escaping... ;)
cheers!
October 28th, 2009, 9:29 pm
gym bunny
cheers Ken, Got the bits on the shelf next to Jeremy. I will swap them over next time I get him out on the drive.
thanks
1299cc FTW
October 28th, 2009, 10:25 pm
