AZL57
 Re: AZL 1957
St.Marc is also a great product in the US cleaner. I use it always in combination with hot water in the US for clock parts.
| April 20th, 2025, 5:54 pm |
AZL57
 Re: AZL 1957
Yesterday i replaced the brake discs a lot of taking parts of to reach the discs. All went well, did put in new brakepads too. On the pads i bought at a french supermarket years ago there was an "how to replace your brakepads" advise.... First step take the wheels of the car.....sleep on...
| April 29th, 2025, 9:13 am |
AZL57
 Re: AZL 1957
My lockable fuel cap like that on the picture came apart in my hands. The rivets that hold the lock ring to the cover gave way. I tried to rerivet them but it didn't hold. So i drilled in the rivets and tapped M3 in there. I screwed it back together with some locktite. Hope it hold now.
| April 30th, 2025, 4:08 pm |
AZL57
 Re: AZL 1957
New problem after rebuilding all parts on the car the choke have become very heavy to use. So this evening i got the whole cable out. Took it apart and when i blow trough the outer cable a lot of dust came out. The inner cable was worn in little dimples. Made by the outer cable over the years. So i did rub it down with sand paper. A bit of grease and all put in again. I can move the choke with 2 fingers now.
| April 30th, 2025, 9:32 pm |
AZL57
 Re: AZL 1957
Passed at the MOT today. All clear i may drive for 2 years again. Nice picture with hanging wheels.
| May 12th, 2025, 4:40 pm |
Geert
 Re: AZL 1957
Conratulations !
| May 13th, 2025, 6:45 am |
AZL57
 Re: AZL 1957
Thanks. It had a little play on the king pivots. Horizontally ??? Never seen that, normally it's vertically. The lower hole seems to be a bit oval front to rear...
| May 13th, 2025, 5:27 pm |
AZL57
 Re: AZL 1957
Bought this mouthpiece for my grease gun. It clicks on and there is no leaking grease at the nipple. Works well. only the blue tube is a bit stiff. I used my old one in rubber.
| May 13th, 2025, 5:33 pm |
Roger V
 Re: AZL 1957
How about a link!
| May 13th, 2025, 7:50 pm |
AZL57
 Re: AZL 1957
https://www.ebay.de/itm/134977048851this is only one you have to check out the lowest price. I payed 8,50. There are dozens of offers. If it might interest someone an other picture off the 2cvs underside at the MOT. Nice dangling wheels.
| May 13th, 2025, 9:10 pm |
Users browsing this forum: No registered users and 135 guests |
