View unanswered posts | View active topics It is currently February 3rd, 2026, 11:30 am
Reply to topic  [ 50 posts ]  Go to page Previous  1, 2, 3, 4, 5
 New with AZ 56
Online
Post Re: New with AZ 56
Do you have an filter in the fuel line? I had once in france that the internals of the fuel filter desintegrated and blocked the carb.
May 17th, 2022, 4:20 pm
ΙI believe this is what Roger V is talking about.
https://citcarclubvic.org.au/wp-content ... stment.pdf
I've Been Wrong Before.
May 17th, 2022, 6:08 pm
Many thanks for your answers and document. that i will study.
About the filter : there was none but I have installed one since.
What is bizarre is that now the engine runs perfectly with a good idling .... until the next time !
I think that i will have to clean the tank , change the rubber pipes and have the carb professionaly cleaned .
I have had the carb of my 56 AZ very well cleaned with vapour blasting by http://cbxvapourblasting.co.uk/
They are specialized in cleaning carbs for the famous CBX 6 cyl Honda bike
Best regards
MG
May 18th, 2022, 9:10 am
Post 2CV6 - Solex 26 35
Hello
Identifying the right Solex 26 35 carb repair kit on the Internet is not easy .
I understand that there are different carburettor versions with different fuel gaskets depending on the CIT codes and CSIC / SCIC codes :
- CSIC or SCIC according to mechanical or centrifugal clutch;
and :
-- CIT 197 CSIC Mechanical Clutch (1978, 2CV6 602cm3),
---CIT 198 SCIC Centrifugal Clutch (1978, 2CV6 602cm3),
---CIT 225 CSIC Mechanical Clutch (1981 to 1990, 2CV6 602cm3),
---CIT 238 CSIC Mechanical Clutch (VISA 652cm3)
For our 1987 2cv6 with mechanical clutch the CIT code should therefore be 225 .
I have not found proper documentation on the different versions of gaskets
so below is the result of my investigations .
Thanks for correcting me
MG
May 19th, 2022, 1:06 pm
This may help
https://ecas2cvparts.co.uk/collections/ ... or-gaskets
May 19th, 2022, 7:28 pm
Yes , of course ! I should have looked at Ecas.
Many thanks Roger !
MG
May 20th, 2022, 12:15 pm
For information
The ECAS Solex refurbishment kit for 2CV6 which has been unavailable for several months has just arrived !
MG .
October 3rd, 2022, 7:38 pm
that's cool :D bring it on :)
October 3rd, 2022, 10:20 pm
Hello
My friend's 2CV6 has been running well for several months since the installation of a good fuel filter.
However the other day it refused to start because no power to the ignition
/ faulty switch under the Neiman key lock
Fortunately replacements are available from Ecas who warns " Buy this new part but please fix your water leaks to prevent failure again. "
Indeed when opening the switch, there was huge corrosion inside , apparently from winsdhield water fluid .
Note that if you open the switch , it is not possible to put it back together ( without special tools )
Thanks to Fer for his advice !
MG
February 25th, 2023, 7:56 pm
Online
You can put it together michel. It's a bit fiddly but it's possible. Put the oxydised parts in vinegar with a few spoons of salt. It will get clean. Only rinse it good afterwards.
February 26th, 2023, 6:25 pm
Users browsing this forum: No registered users and 441 guests
