We have liftoff.....AZU 250 rebuild thread
subarupete
Joined: March 5th, 2009, 6:23 pm Posts: 2257 Location: Near Monmouth
 Re: We have liftoff.....AZU 250 rebuild thread
Great bit of fabrication work.
| September 28th, 2020, 7:09 pm |
Roger V
Its amazing what you can do with a hula hoop! Love it.
| September 28th, 2020, 7:42 pm |
48pop
Joined: May 23rd, 2011, 7:14 pm Posts: 309 Location: ecosse
Due to tight confines of the adapter, i needed to buy some M7 allen head bolts........12 quid for 5 !!!
Damn you Citroen and your M7 fetish !
| September 28th, 2020, 7:58 pm |
Roger V
I drilled and tapped to M8
| September 28th, 2020, 8:19 pm |
48pop
OK, doing a bit of a dash swap today, simple and now MPH...... I find I have a few spaces, I've seen blanks for the wee round holes, are blanks available for the rectangular holes ?? Also, I need a working wiper switch...anyone have these bits for sale? Swap was very awkward and fiddly....... Mostly working and I now have an oil warning light......and, no front lights.....Will get it finished over next week !
| October 4th, 2020, 11:28 pm |
Geert
Joined: July 10th, 2010, 12:35 pm Posts: 1205 Location: Magyarország
Ask Roger V if he can print these blanks . He owns a 3D printer as I understand
| October 5th, 2020, 9:41 am |
AZL57
The little lights you can take out of the other dash they are the same. Dash is normally fixed with this type of lense shape screws.
| October 5th, 2020, 11:08 am |
Roger V
I moved my hazard switch to the left side. The two holes at the top I use for left and right indicators. The wiper switch stayed in the bottom right corner. However, in the square hole above it, i have repurposed the brake fluid test bulb button to operate the electric windscreen washer pump.
| October 5th, 2020, 11:42 am |
Ianredspecial
Joined: June 22nd, 2014, 8:09 pm Posts: 1326 Location: Reading, Berks UK
Electric washer pump?? Poshe.
| October 6th, 2020, 12:16 am |
48pop
OK, confused.......
As above, I've swapped the dash. Car starts and runs, I have tail lights, indicator and horn.....I have no front lights, nothing, no sidelights, no dipped headlights and no full beam.
I did have the lightswitch disconnected but I have checked and its all back as before. My meter says I have 12+ volts coming to switch and when I turn the knob, 12+ volts at all other terminals (except horn)
Any thoughts on what I've missed before I tear it all out again.....?
(I had lights before the swap)
| October 7th, 2020, 2:45 pm |
Users browsing this forum: No registered users and 204 guests |
