View unanswered posts | View active topics It is currently August 14th, 2025, 2:25 pm
Reply to topic  [ 343 posts ]  Go to page Previous  1 ... 18, 19, 20, 21, 22, 23, 24 ... 35  Next
 My Beduino
Post Re: My Beduino
there is a firm in the us that makes copper head gaskets on measure.
January 11th, 2020, 6:15 pm
Post Re: My Beduino
Well, that shows its not to uncommon. I'll try making my own. Always seem To have an issue with the exhaust manifold blowing, so thought it may be more resilient. :)
January 11th, 2020, 9:26 pm
Post Re: My Beduino
Ecas do a copper one. I used it but it didn't do any good for my endlessly blowing manifold.
Timeserts were the way forward for me. Not put in by me, crucially....
January 12th, 2020, 11:30 pm
Post Re: My Beduino
Ian
I dont recall ecas doing a copper exhaust gasket! They do a 'carbon fibre' gasket, or copper plated nuts, but cant see a copper gasket. :)
January 12th, 2020, 11:48 pm
Post Re: My Beduino
Pretty sure I got them from there, by ringing Roy.
January 13th, 2020, 2:05 am
Post Re: My Beduino
Thanks Ian, I'll bear that in mind. :)
January 14th, 2020, 11:41 pm
Post Re: My Beduino
I've installed the MAP pipe over the last few days. The sensor is on the ECU, and there is a pipe to the manifold.
MAP at idle is hovering around 55 kpa which is quite high.
January 19th, 2020, 5:55 pm
Post Re: My Beduino
Do you have the right sensor configered in the software???
Is it around 100 when the engine doesn,t run.. (100 is the airpressure)..
January 20th, 2020, 1:16 pm
Post Re: My Beduino
Hi Geo
Yes, I'm sure its correctly configured.
What MAP do you get at idle? That will give me a target to aim for. :)
Edit
There is a different sensor in the drop down list. I will try it tomorrow. :)
January 20th, 2020, 8:31 pm
Post Re: My Beduino
My 2cv whit Mega Squirt i about 50 kpa at idle
Image 2cv special 0,6Tii
viewtopic.php?f=5&t=1610
January 22nd, 2020, 5:27 pm
