View unanswered posts | View active topics It is currently July 3rd, 2025, 5:25 pm
Reply to topic  [ 959 posts ]  Go to page Previous  1 ... 41, 42, 43, 44, 45, 46, 47 ... 96  Next
 AZL 1957
Post Re: AZL 1957
rob massey55 wrote:
https://d1dq9tiesi76an.cloudfront.net/pub/media/catalog/product/cache/1/image/e9c3970ab036de70892d86c6d221abfe/i/n/india-circus-prismatic-hexagons-oven-mitts-27237-1.jpg
:D :D
July 24th, 2019, 9:14 pm
Post Re: AZL 1957
Took the 57 out for winter duty. Bit of air in the tyres, cleaned the spark plugs. That's all. It started just fine after 7 months of sleep. I like those old beasts.
November 16th, 2019, 7:48 pm
Post Re: AZL 1957
Smelled a bit of exhaust in the car i suspected the manifold nuts but after a check in the sun i did see a crack in it just under the carb. So took the dremel out an grinded the crack clean. Then i took the welder out and fixed that problem too. In between preparing my dad's peugeot van for selling. As it is a diesel that won't be easy.
November 16th, 2019, 10:31 pm
Post Re: AZL 1957
Send it to Hunary, there are a lot of diesel-cars over here and nobody cares :lol:
November 17th, 2019, 8:47 am
Post Re: AZL 1957
We had lot of rain yesterday (40+mm) and the 57 started leaking through inside. It came in via all the little nuts of the vent flap. Never seen that before. I think the rubber of the flap has dried out. Have to find a solution. Other than replacing the rubber ;-)
November 19th, 2019, 9:34 am
Post Re: AZL 1957
Loosen the nuts of the trim and put some sealant between trim and rubber and rubber and body around the studs. Then tighten everything again...
November 19th, 2019, 10:11 am
Post Re: AZL 1957
Maybe later, i did let wd40 run in with a little brush from the outside between rubber and trim. Might go the same direction as the water and seal it off. We'll see. ;-)
November 19th, 2019, 8:19 pm
Post Re: AZL 1957
Or maybe this stuff, which has worked well for me with windscreen seals...
https://www.ebay.co.uk/itm/GOT-LEAKS-Tr ... xyVLNSzS~6
November 19th, 2019, 11:40 pm
Post Re: AZL 1957
Thanks for the tip.
November 20th, 2019, 7:44 pm
Post Re: AZL 1957
Nice sunny morning no leaking ventflap today :mrgreen:
November 20th, 2019, 9:08 pm
