Geert
 Re: AZL 1957
rob massey55 wrote: https://d1dq9tiesi76an.cloudfront.net/pub/media/catalog/product/cache/1/image/e9c3970ab036de70892d86c6d221abfe/i/n/india-circus-prismatic-hexagons-oven-mitts-27237-1.jpg
| July 24th, 2019, 9:14 pm |
AZL57
 Re: AZL 1957
Took the 57 out for winter duty. Bit of air in the tyres, cleaned the spark plugs. That's all. It started just fine after 7 months of sleep. I like those old beasts.
| November 16th, 2019, 7:48 pm |
AZL57
 Re: AZL 1957
Smelled a bit of exhaust in the car i suspected the manifold nuts but after a check in the sun i did see a crack in it just under the carb. So took the dremel out an grinded the crack clean. Then i took the welder out and fixed that problem too. In between preparing my dad's peugeot van for selling. As it is a diesel that won't be easy.
| November 16th, 2019, 10:31 pm |
Geert
 Re: AZL 1957
Send it to Hunary, there are a lot of diesel-cars over here and nobody cares
| November 17th, 2019, 8:47 am |
AZL57
 Re: AZL 1957
We had lot of rain yesterday (40+mm) and the 57 started leaking through inside. It came in via all the little nuts of the vent flap. Never seen that before. I think the rubber of the flap has dried out. Have to find a solution. Other than replacing the rubber
| November 19th, 2019, 9:34 am |
lpgo
 Re: AZL 1957
Loosen the nuts of the trim and put some sealant between trim and rubber and rubber and body around the studs. Then tighten everything again...
| November 19th, 2019, 10:11 am |
AZL57
 Re: AZL 1957
Maybe later, i did let wd40 run in with a little brush from the outside between rubber and trim. Might go the same direction as the water and seal it off. We'll see.
| November 19th, 2019, 8:19 pm |
 Re: AZL 1957
Or maybe this stuff, which has worked well for me with windscreen seals... . https://www.ebay.co.uk/itm/GOT-LEAKS-Tr ... xyVLNSzS~6AZL57 wrote: Maybe later, i did let wd40 run in with a little brush from the outside between rubber and trim. Might go the same direction as the water and seal it off. We'll see.
| November 19th, 2019, 11:40 pm |
AZL57
 Re: AZL 1957
Thanks for the tip.
| November 20th, 2019, 7:44 pm |
AZL57
 Re: AZL 1957
Nice sunny morning no leaking ventflap today
| November 20th, 2019, 9:08 pm |
