View unanswered posts | View active topics It is currently July 5th, 2025, 6:55 am
Reply to topic  [ 780 posts ]  Go to page Previous  1 ... 38, 39, 40, 41, 42, 43, 44 ... 78  Next
 Van repairs
Post Re: Van repairs
Imagenew pix 010 by Robndaisy, on Flickr
May 27th, 2018, 12:33 am
Online
Storm ?
It does n't look like what I had in mind at all .
May 27th, 2018, 7:04 am
Imagenew pix 008 by Robndaisy, on Flickr
Five years ago, when I was repairing the Charleston. First tent bailed out so had to buy the present one. 6m.x3m. for £200.00 has been a good tent but starting to show it's age now.
May 27th, 2018, 9:25 am
Last national I was at, my tent looked like that when I put it up!
May 27th, 2018, 10:27 am
ImageP1010885 by Robndaisy, on Flickr
ImageP1010884 by Robndaisy, on Flickr
The wiring begins, I'm running the wires from the engine compartment, up and over the door tube. We decided to crimp them and pull 'em with the 'fishing' wire that we'd already poked through.
ImageP1010887 by Robndaisy, on Flickr
Not forgetting to install PVC conduit first.
ImageP1010888 by Robndaisy, on Flickr
Gently tugging the flamer along :) .
May 27th, 2018, 8:24 pm
ImageP1010902 by Robndaisy, on Flickr
As is to be expected on this Flamer :roll:, the light switch stalk was seized and unable to operate the horns.
ImageP1010900 by Robndaisy, on Flickr
Luckily I managed to disassemble it.
ImageP1010896 by Robndaisy, on Flickr
A bit of emery and some petroleum jelly and good to go, beep Beep.
ImageP1010903 by Robndaisy, on Flickr
That's it's 60 year service done then.
ImageP1010911 by Robndaisy, on Flickr
ImageP1010908 by Robndaisy, on Flickr
ImageP1010906 by Robndaisy, on Flickr
ImageP1010909 by Robndaisy, on Flickr
The plan is to make the loom up as I go along, test it and remove it to wrap it.
No fuse box fitted :o :? :?: .
May 28th, 2018, 9:04 pm
That's the true spirit..
May 28th, 2018, 10:33 pm
Fuse box good ..... Burnt wires bad ....
Cider good ............ Cider very good ..... :D
May 28th, 2018, 10:40 pm
ImageP1010914 by Robndaisy, on Flickr
Let's have look inside 'cos one side is flashing and the other isn't.
ImageP1010915 by Robndaisy, on Flickr
ImageP1010916 by Robndaisy, on Flickr
ImageP1010917 by Robndaisy, on Flickr
Yes it's a wonderfully elegant Steam Punk world of what seem to be electrically operated bi-metallic strips and lots of contacts. nothing appeared to be burnt out so I used some 1200 grit to clean the points and some cotton buds and thinners for the other contact areas. The dremel and it's little wire brush helped a lot. Put back together and...
ImageP1010924 by Robndaisy, on Flickr
^^Click on the image for video^^
Question, is this normal for a '50's Citroen. I don't have any experience of how the Scintex flasher/timer is supposed to be.
ImageP1010921 by Robndaisy, on Flickr
Parking lights are back in service on their original bulbs.
ImageP1010923 by Robndaisy, on Flickr
That's on low beam , a P45t 6 volt bulb in a Valeo reflector and a plastic shell. I hated taking off the original shells, so well made, so it goes... :) .
June 2nd, 2018, 10:25 pm
Wow, huge progress :D
I love it when a van comes together :lol:
Let me know if you need anything from Wicked!
June 2nd, 2018, 11:56 pm
