View unanswered posts | View active topics It is currently July 4th, 2025, 11:39 am
Reply to topic  [ 780 posts ]  Go to page Previous  1 ... 33, 34, 35, 36, 37, 38, 39 ... 78  Next
 Van repairs
Post Re: Van repairs
Aah! Sunshine, Spring, the holiday weekend, so...
ImageP1010813 by Robndaisy, on Flickr
Ran the fuel line (steel pipe originally, nylon and rubber now) to the pump. found this bracket which I have no memory of but it seems to want to go here.
ImageP1010810 by Robndaisy, on Flickr
Set the spring on the accelerator rod with a cable tie to ease the pressure of the spring I'm using (ECAS later spring): tried it direct to the bulkhead and it was too strong, the rod was bending :!:
ImageP1010808 by Robndaisy, on Flickr
I decided to use the new pedal just to see if it was easier to set the flamer up. The one I've inherited shows signs of 'pedal to the floor' or whatever the French expression is (German was taught at my Grammar (Ellesmere Port) 'cos we were twinned with an equivalent Deutsche town of Reutlingen
ImageP1010811 by Robndaisy, on Flickr
This is an initial set up :?
ImageP1010812 by Robndaisy, on Flickr
Some more work needed or a piece of tractor inner tube, cunningly cut (steady now :shock: ) to provide the seal required.
I don't know about you, but this is how I steal a Donations Box. (Turning up early is best ;) ).
ImageP1010784 by Robndaisy, on Flickr
ImageP1010789 by Robndaisy, on Flickr
ImageP1010802 by Robndaisy, on Flickr
Happy Days :mrgreen:
May 5th, 2018, 8:57 pm
Hi Rob that bracket suposed to go on top of the gearbox to hold the wire loom. The fuel line is hold by a halfround bracket to the chassis. (like a cable clamp)
May 5th, 2018, 10:20 pm
Cheers Fer, one less thing to wonder about ;) .
May 5th, 2018, 10:27 pm
ImageP1010825 by Robndaisy, on Flickr
Same piece of shed hinge but popped onto a new pedal, quality work going on here :lol: .
ImageP1010827 by Robndaisy, on Flickr
ImageP1010828 by Robndaisy, on Flickr
Right , that's done and I fitted the fuel line, all clipped in sweetly.
On to the front brake lines etc.
ImageP1010829 by Robndaisy, on Flickr
So far so good...
ImageP1010830 by Robndaisy, on Flickr
Damn! got the short double banjo pipe the wrong way round :roll:
Eventually got everything lined up nicely, copper washers annealed and tightened it all up. feeling dead happy I went to fit the bleedscrews before finishing for the day and they wouldn't start at all :evil: The hex on the screw was fouling on the flamin' banjo. So undid all my good work and thought about torching the van and the tent and going and getting well and truly p*ssed and switching to C 15's.
Calmed down eventually after running out of swear words and curses. Swung the feckin' banjos around a bit and eventually got the bleedscrews to loosen and tighten up again. Time for a beer now though :mrgreen: .
May 7th, 2018, 6:32 pm
Well done, beer will help...
May 7th, 2018, 9:33 pm
I find two beers helps twice as much ;)
May 8th, 2018, 12:12 am
ImageP1010834 by Robndaisy, on Flickr
Nylon washers both sides and copper grease eventually.
ImageP1010835 by Robndaisy, on Flickr
ImageP1010836 by Robndaisy, on Flickr
ImageP1010837 by Robndaisy, on Flickr
ImageP1010838 by Robndaisy, on Flickr
I've won the Raffle/Lottery :lol:.
ImageP1010839 by Robndaisy, on Flickr
ImageP1010840 by Robndaisy, on Flickr
ImageP1010841 by Robndaisy, on Flickr
I've no idea what this bracket is for, I think it came off near the front wing area many years ago: anyone know?
May 12th, 2018, 7:28 pm
postal and edf vans had several reinforcement parts maybe that's one of those?
May 12th, 2018, 10:30 pm
Cheers Fer, I'll straighten it out and try and find it a home ;) .
May 12th, 2018, 10:55 pm
Maybe it's more recognisable when straightend. Was it spotwelded or just bolted on?
May 13th, 2018, 8:29 am
