2cy
 Heater ducting tubes
The (summer) time has come to replace the heater ducting.. Can anyone advise where is the least expensive to buy this stuff from ?
..or perhaps someone has used none Citroen tube and found it both inexpensive and durable.
Thanks ;)
| July 4th, 2017, 3:40 pm |
lpgo
 Re: Heater ducting tubes
I always use Webasto caravan ring heater pipe..
| July 7th, 2017, 10:59 pm |
and earplugs? lpgo wrote: I always use Webasto caravan ring heater pipe..
| July 7th, 2017, 11:06 pm |
lpgo
Something like this.. I use it more then 25 years Attachment:
| July 7th, 2017, 11:07 pm |
lpgo
ken wrote: and earplugs? lpgo wrote: I always use Webasto caravan ring heater pipe.. Please Ken write louder I can't here you..
| July 7th, 2017, 11:08 pm |
Roger V
As Ken is suggesting. You will appreciate something that deadens the sound from my he engine bay. No .... really .... trust me on this.
| July 8th, 2017, 12:23 am |
Geert
Joined: July 10th, 2010, 12:35 pm Posts: 1203 Location: Magyarország
LPGO is wearing hearing protection when driving his 2CV ! https://www.youtube.com/watch?v=tQGglnT35c8
| July 8th, 2017, 7:24 am |
2cy
Thanks lpgo for the suggestion. I'll check it out. noted absence of suggestions from those with a sense of humour
| July 15th, 2017, 2:25 pm |
rob massey55
I've always found the cardboard/foam lined tubes, eg. from Staffordshire very good and long lasting if you fit them carefully, ie. trim them to get the tightest fit and support them with straps where necessary. Some folks waterproof the outer cardboard. The problem areas, on my 2CV anyway, are the exits from the heat exchangers which are very short.
| July 15th, 2017, 8:18 pm |
Jonathan
If you're talking about the crappy cardboard tubes that go through the front inner wing and last 5 minutes in the wet, then try these more expensive but far superior rubber ones from ECAS. They are well worth paying the extra for. https://www.ecas2cvparts.co.uk/heater-e ... e487451770
| July 15th, 2017, 11:16 pm |
Users browsing this forum: No registered users and 96 guests |
