View unanswered posts | View active topics It is currently April 29th, 2026, 5:35 pm
Reply to topic  [ 28 posts ]  Go to page 1, 2, 3  Next
 Earth strap
Post Earth strap
Hi everyone
Should there be an earth strap from the battery to the body of the car? I have one to the engine, but as the engine is rubber mounted, I can't see there would be a good negative connection!
March 16th, 2017, 3:54 pm
Post Re: Earth strap
Yes,
I have one , it is connected to the battery-clamp .
March 16th, 2017, 4:22 pm
Thanks Geert
I did wonder as my voltage regulator is not working correctly. Thought perhaps it was a bad earth!
How heavy is the cable? How many amps are we talking about?
March 16th, 2017, 5:13 pm
Same as the + side.
See photo neg directly to the gearbox stud.
also a strap from gearbox to body
ps
Think about it :o
March 16th, 2017, 5:31 pm
It is only very thin in comparency with the cable to the gearbox
I think it is 1,5/ 2 mm .
ImageDSCF0818 by geert1953, on Flickr
ImageDSCF0817 by geert1953, on Flickr
March 16th, 2017, 5:52 pm
I've ordered a 90 amp braided one and I think I'll go from battery to body to avoid wear and tear from the engine movement.
Still puzzled on where it was making a circuit though.
March 16th, 2017, 6:07 pm
To the airinlet, next to the battery
March 16th, 2017, 6:16 pm
I was always wondering about this thin earth wire, but never disconnect it to see what happens.
Time to try it.
Hard to believe that all that current (excluding the starter) passes through it.
I've Been Wrong Before.
March 16th, 2017, 10:35 pm
yes it does, same size cable like the one that goes form the start + to your contact.
March 16th, 2017, 10:48 pm
You're right AZL57.
Nevertheless it worths an upgrade review.
March 17th, 2017, 11:29 pm
