Vosper2004
Joined: October 30th, 2009, 10:00 am Posts: 80 Location: Farrington Gurney, Nr Bristol
 brake fluid loss
Hi, I'm noticing a small loss of brake fluid over a period even when the car has not been driven, not massive but enough to trigger the warning light. Possibly from the reservoir area. Is it likely to be just the reservoir or more serious? Don
| January 3rd, 2017, 12:30 pm |
bobh
 Re: brake fluid loss
Could be anything. Its time to look underneath at all the pipes / flexibles, rear brake drums for sign of leaks and front drums/calipers and don't leave out looking at the master cylinder. Yes, It may be a cracked reservoir, but I would want to check this out before I trusted my life on a leaky system.
| January 3rd, 2017, 1:44 pm |
lpgo
Also check inside the car, at the brake-pedal erea. Sometimes the master brake cilinders leaks to the inside of the car.
| January 3rd, 2017, 1:56 pm |
Vosper2004
Thanks for the replies. I couldn't see any obvious cracks in the reservoir. I'll check out the pipes and the pedal area. I see that seals are obtainable as well as the reservoir itself. How is it retained? Does it just pull off? Don
| January 3rd, 2017, 3:20 pm |
knightley
Joined: June 19th, 2010, 8:40 pm Posts: 761 Location: Kingswood, S.Glos.
Vosper2004 wrote: How is it retained? Does it just pull off? Don Yes, wiggle and pull.
_________________ John Jordan
| January 3rd, 2017, 5:34 pm |
jasu
Joined: August 8th, 2012, 11:00 am Posts: 508 Location: Korpilahti, Finland
Those seals under reservoir, are very often leaking at cold. Because of seal material, nitrile, it shrinks a little. All my cars have LHM and every of them leaves a green spot under at winters, Dyanes under LHM reservoir, Xm and Sm from many places where they doesn't leak at summer...
| January 3rd, 2017, 6:02 pm |
However, I think you will find that it's much easier to disengage the reservoir by pushing or pulling it to one side, so that the bayonet-shaped prongs 'roll' out of the seals... knightley wrote: Vosper2004 wrote: How is it retained? Does it just pull off? Don Yes, wiggle and pull.
| January 3rd, 2017, 6:37 pm |
Vosper2004
Thanks for the info. A couple of new seals is probably worthwhile. The fluid loss is certainly worse in this cold weather and the MoT chap recently had a good poke around underneath and didn't spot any leaks etc. Cheers Don
| January 4th, 2017, 11:10 am |
richardmorris
Joined: July 9th, 2009, 10:27 am Posts: 493 Location: Bagshot Park
My only leak( so far) was where the rough welds on one of the rear suspension arms wore through the brake pipe.
| January 6th, 2017, 12:15 am |
Vosper2004
I've got a couple of the seals on their way and I'll change them anyway. The latest fluid loss took place whilst the car was standing for about ten days over the Christmas period. I haven't ruled out a leak from the pipes so I'll get the car over the pit when the garage is clear. I had a couple of advisories re the kingpins and I haven't renewed the brakepads for a while so I'll be giving it a good going over when the weather warms up a bit. Whilst on the subject of brakes, I don't have a rear hub extractor. Any recommendations? Cheers Don
| January 6th, 2017, 11:52 am |
