View unanswered posts | View active topics It is currently April 28th, 2026, 2:30 am
Reply to topic  [ 1048 posts ]  Go to page Previous  1 ... 38, 39, 40, 41, 42, 43, 44 ... 105  Next
 Make Your Own ....2CV.... 4x4
Only Tensile 8.8
but has worked (so far) on a few off-road cars.
March 28th, 2015, 4:45 pm
Pony wrote:
much more fun to snap one in the mud!
pony
This is what happened to my AMI 4x4, snapping a hexagon knifeedge eye.... in the middle of "Domaine de Bilstain" kneedeep mud... Luckely I had a spare with me...
Never use hexagone knifeedge eyes since then...
March 28th, 2015, 8:10 pm
This Part
Knife Edge
Not This part
Tie Rod Eye
Tie Rod
March 28th, 2015, 8:21 pm
ignore... :oops:
March 28th, 2015, 8:23 pm
The tie rod eye snapped, but the one with a big nut welded on insted of a nice round one...
March 28th, 2015, 8:55 pm
Actually we have used M12 10.9 bolts for pins on the 4x4 for years without problems
I started to use bolts as most replacement pins are not the correct material ( soft)
normally we see the tie rod stretching same with the M12 threaded rod
and not failing where it enters the eye!
Nearly all of these issues about broken rods are directly linked to having no rubber bump stops
which causes the rod to stretch at its weakest point.
I believe the original pin was so shaped to stop it rotating on the arm knife edges
since this rotation would wear away (enlarge) the hole!
pony
March 28th, 2015, 9:32 pm
I think Ken had the correct description of why knife edges are designed that way and also why mine failed.
March 28th, 2015, 9:39 pm
Ready? for Morvan.
March 31st, 2015, 12:10 pm
Can weight 820KG
Seems I lost the bet!
March 31st, 2015, 12:13 pm
subarupete wrote:
Can weight 820KG
You see: I told you already... ;) ;) ;) ;)
subarupete wrote:
Total 590 Estimate
March 31st, 2015, 12:23 pm
