View unanswered posts | View active topics It is currently April 28th, 2026, 2:54 pm
Reply to topic  [ 1048 posts ]  Go to page Previous  1 ... 36, 37, 38, 39, 40, 41, 42 ... 105  Next
 Make Your Own ....2CV.... 4x4
Video on Youtube.....
:D :D
https://www.youtube.com/watch?v=16ZdC7- ... e=youtu.be
March 22nd, 2015, 7:24 pm
Yep it works... Did you only have frontwheels engaged??? otherwise your cheating with your rearwheels....
So if I understand right you are braking the left frontwheel (looking from your view inside the car) so the right wheel gets traction....
How does it work?? do you pull some switches and then press the brake?? Please explain..
March 23rd, 2015, 12:11 am
In Front Wheel drive only.
Push the brake pedal.
Close the switch for Left front wheel.
Drive off :D
The diagram show an ABS shuttle valve.
The text shows how is used in an ABS set up.
I use the valve with the other way round (reverse arrows).
When the pedal is released the valve stays shut under pressure
March 23rd, 2015, 9:12 am
Switch Panel.
Main Kill switch.
Front/Rear Toggle switches to select which wheel.
March 23rd, 2015, 4:18 pm
Freaking cool... Leaving mister Pony with lots of unsellable diffs :D :D :D :D
So the next level is to put an Arduino in??
March 23rd, 2015, 9:22 pm
and when you release the power from the valve, the valve opens and your wheel doesn't brake anymore??
March 23rd, 2015, 9:25 pm
@and when you release the power from the valve, the valve opens and your wheel doesn't brake anymore??
With no power to soleniod/shuttle-valve, fluid passes thru and brakes work in the normal way.
Just like an ABS system during normal braking.
March 24th, 2015, 9:37 am
New cover for rear diff/brakes and finished the extra brake pipes.
March 24th, 2015, 5:41 pm
looks like i had better shut the shop ,
so no chance to sell more Quaife!!!!!
bugger i thought after selling 150 of then there could be a future
How wrong i was!!
i will move over to making furniture and beds
and throw all my last 20 years off road experience experience in the bin,
probably buy a fiat panda 4x4 and retire to Spain
Ahhhhhhhhhhhhhhh
pony
March 25th, 2015, 10:40 pm
:D :D :D :D :D :D :D :D
March 25th, 2015, 11:32 pm
