View unanswered posts | View active topics It is currently April 29th, 2026, 11:52 am
Reply to topic  [ 1048 posts ]  Go to page Previous  1 ... 34, 35, 36, 37, 38, 39, 40 ... 105  Next
 Make Your Own ....2CV.... 4x4
Eh just if i did not let you know
i got lots of Visa gear wheels from the boxes that i strip for my rear diff project
if you are in need of sommit special!
let me know
pony
October 24th, 2014, 7:03 pm
Are you going to Daingy?
October 24th, 2014, 8:03 pm
Not that happy with the fuel tank in the front, so the plan to fit a half size jerry can in the rear.
Made an adaptor from a standard jerry can filler pipe.
Pipe 1 is the fuel line, Pipe 2 is the breather. The standard breather hole is filled with Expoxy putty.
October 25th, 2014, 2:22 pm
The beast is too noisy, so sourced some small silencers.
Need to make some new pipes to fit silencers one each side in the rear wing
November 6th, 2014, 5:32 pm
Going to Morvan at Easter.
It runs/goes but some improvements to be done.
Second Silencer.
Replace gear lever to the long version.
Fit Engine Cover.
Fit Rear Wing drivers side.
Add reinforcement to rear gearbox mount.
Bleed Front Brakes
If time semi-fiddle brakes.
ps
Have a spare seat if anyones intersested (i doubt it)
March 18th, 2015, 4:46 pm
Added some braces to rear diff mount.
Not very tidy, but needs the body off to do a re-design.
Larger access hole now needs a new larger cover.
March 19th, 2015, 5:13 pm
Modified the exhaust by adding the damaged cross-box from the Bokkerijders event
Still not as quite as a standard system, but much better that it was.
Why chuck it in the bin?
Adapt and reuse...
March 20th, 2015, 4:43 pm
i love those rusty rear discs
pony
T shirts in stock for Morvan
March 20th, 2015, 9:33 pm
They will buff up with a Brillo pad :D
March 20th, 2015, 11:05 pm
Just hit the brakes a couple of times and they will shine...
March 20th, 2015, 11:16 pm
