View unanswered posts | View active topics It is currently August 13th, 2025, 1:40 pm
 what size thread - suspension tie rods
Post what size thread - suspension tie rods
Come on you clever lot what size thread are the suspension tie rods
Thanks
Simon
March 7th, 2015, 10:12 pm
Post Re: what size thread - suspension tie rods
11 x 1 mm
Thanks Viking - thats a good size as I have both a tap & die that size :D
March 7th, 2015, 10:47 pm
Simon,
best not to go overboard with those taps and dies.
The threads on the tie rods were rolled, not cut and any reduction in the major diameter of the thread might cause a problem, especially with uprated springs...
March 8th, 2015, 1:54 am
thanks Ken for that, will take care
March 8th, 2015, 9:18 am
i know you can get un fluted taps ( slightly triangular in shape , they push softer metals into the thread form rather than cutting) but can you get un fluted dies?
March 8th, 2015, 10:47 am
I chopped up an old tie rod end to clean my threads up.
I cut the loop off the end and cut a slit along the length with one of those skinny cutting discs.
I intended to weld a big nut in the middle of it but didn't need to in the end.
Worked for me.
March 8th, 2015, 11:40 am
ken wrote:
Simon,
I've ''cleaned'' tie rod end threads for years using a ''standard'' 11 x 1 mm die. Never seen one fail. Even totally over loaded 2cvs driving on 10 million corrugations in the out back and still not coming apart. The rod will snap yes but the thread is pretty strong, despite only a centimeter or so, is holding on to the end eye.
March 8th, 2015, 1:25 pm
Broken Tie Rod Eye.
March 8th, 2015, 2:07 pm
yep i too have re threaded many tie rods with no probs for off road
Broken eye holes are quite common!
pony
March 8th, 2015, 10:07 pm
Users browsing this forum: No registered users and 23 guests
