Joined: May 3rd, 2009, 11:40 am Posts: 816 Location: Melbourne, Australia.
 Re: The Nameless AZU
Tripyrenees wrote: when the shelves start emptying of parts and the cleaning is finished, it starts to seem worth while...... Everytime I rebuild a car I have a box of parts left over! Harley
samfieldhouse wrote: It is M9 for the shocks yes, the rest I'll check when next i'm underneath her. Ironically, this will be valentines day.
| January 18th, 2015, 8:15 pm |
citroenboat
I have been doing stuff on this, just not been arsed to do the real work of posting on here.... So, I got the bulkhead out, then I wimped out of making one as I found this : http://www.renov-2cv-mehari36.com/en/bo ... model.htmland thought hey, bit of reworking, it'll do a treat. More on that later. Having now got a good view of the parcel shelf & binnacle I decided the parcel shelf was beyond the pale too - and Renov do this... http://www.renov-2cv-mehari36.com/en/bo ... -2cv6.html- s'only money So everything came out : Attachment:
The binnacle had suffered badly along the bottom edges & up the two r/angle braces for the rear of the battery box : Attachment:
A bit of chopping & bending later : Attachment:
And then some filling & painting - not too fussed about the inside having some lumpy weld as it will be invisible
_________________ Mike
Last edited by citroenboat on February 28th, 2015, 3:59 pm, edited 1 time in total.
| February 28th, 2015, 3:43 pm |
citroenboat
All the brackets for the handbrake, gear lever and all the captive nuts for the 8mm head bolts got removed from the old panels and the brackets were plug welded to the new parcel shelf - also the little body number plate that is folded through 2 slots in the r/h underside of the parcel shelf got transfered, looong befor the parcel shelf got welded in! Attachment:
Then there was a lot of 'fitting' - bending the ends about so it sat snuggly between the 'A' posts, trying to decide EXACTLY where the binnacle sits - this relaxing hobby can be very stressfull you know?! Attachment:
And finaly with much trepidation the parcel shelf was plug welded to the cross bar and the ends buzzed on to the 'A' posts... Attachment:
| February 28th, 2015, 3:57 pm |
citroenboat
There is a fair bit of difference between the old bulkhead and the new panel I got. Most obvious being the placing of the heater inlets and the holes for the master cylinder/hanging pedal box. Attachment:
I want to put the modern pedal box in the van so I can run an M28 in it thus I've used the heater duct holes as supplied. Their position will still accept the heater tubes from a 425/M4 whereas getting an M28 to connect to the early position ducts is a pain. In order to get the master cylinder mount on the bulkhead the l/h duct has to move anyway. Getting the old type handbrake & the vent operating rods through is a bit of a challange. Most of the rest of the work on the bulkhead was captive nuts & studs. These are around the gear shift, handbrake & demister 'oles. The gear shift hole has to pe enlarged a bit for the old braced gear shift. Attachment:
Last week I had 13 year old nephew as a garage slave so we got the body off the chassis (he plays rugby...) Attachment:
And as a reward(?) he got to strip the heads off the vans engine & find out why it wouldn't run - well that was the plan. It did run & he did actually lap some valves but somehow I ended up doing most of it  He did like the 6inches of flame out of the end of the manifold tho  He spends a lot of time @ Santa Pod and thinks that's how all engines should behave. There's potential there... Attachment:
| February 28th, 2015, 6:56 pm |
AZL57
Joined: October 22nd, 2014, 10:59 pm Posts: 2299 Location: South-Limburg
nice sahara airfilter you have on the engine.
| February 28th, 2015, 11:50 pm |
2cvkeza
Joined: February 11th, 2010, 11:36 am Posts: 603 Location: Slovenia
If any of you AZU "freaks" need panels for it ... take a look at my shop ... http://citroen-2cv.moja-kosarica.si/si/iskanje/AZU/Some of my AZU panels are available also at ECAS http://www.ecas2cvparts.co.uk/advanced_ ... kz&x=0&y=0
_________________ www.2cvkeza.com
| March 1st, 2015, 10:52 am |
citroenboat
It seems to be PO spec, also has the PO front bumper.
| March 1st, 2015, 11:56 am |
bobh
Whilst talking about bulkheads (its a bit late now), I came across this sketch I made when I made mine.
| March 3rd, 2015, 9:59 am |
citroenboat
Cheers Bobh that's still useful - querying some of the dimensions on the new panal, a second set of eyes on the measurements is v. helpful
| March 3rd, 2015, 12:15 pm |
bobh
measurements taken off a 1963 french LHD AZU Fourgonnette.
| March 3rd, 2015, 4:59 pm |
Users browsing this forum: No registered users and 398 guests |
