View unanswered posts | View active topics It is currently July 18th, 2025, 3:39 pm
Reply to topic  [ 3993 posts ]  Go to page Previous  1 ... 265, 266, 267, 268, 269, 270, 271 ... 400  Next
Monel ones I've used had a vague yellow tinge to them....
Mike
January 22nd, 2015, 1:17 pm
Lashed out on a Gas Heater :o
Now the spanners wont be so cold :)
January 22nd, 2015, 3:32 pm
Just took mine in for repair. Bloody thing bellows out smoke after a minute and chokes me out.
I tried adjusting it but no good. And worst thing it is only 2 months out of warranty. But bloody hell it is cold in the garage at the moment.
January 22nd, 2015, 4:49 pm
Spent a lot on small diesel type. Flames and fuel at start up, on restart smoked me out..
Tried it for a 2 days, took it back, as it "Not Fit For Purpose". Swapped for a Propane heater, not as cheap to run, but starts first time no problems.
January 22nd, 2015, 5:20 pm
Are they aluminium rivets?
Yes, aluminium.
January 22nd, 2015, 5:59 pm
Alu Pop rivets are great and maybe the only option for Blind locations, but they can work loose over time.
If you can access both sides of the work try Aircraft style rivets, they are available on Ebay along with a Rivet set and not expensive.
Rivet Set.
Rivets
My Hinge Fixing - 5years old
The tidy side is where the Rivet set is used, This side is finished? with the Ball part of a Ball Peen Hammer
January 22nd, 2015, 6:22 pm
The car I bought, had the hinge mounted with rivets and sealant.
And it hadn't moved a mm for ten years.
There was some surface rust 10 cm from the edge in each side, but usually the entire hinge is gone in that time.
January 22nd, 2015, 9:58 pm
Aluminium and galvanised coatings react together.
January 22nd, 2015, 10:35 pm
If zinc plated steel rivets are used, that would be OK according to these folk... ;)
( Section 5A, galvanic corrosion)
http://www.ajaxfast.com.au/downloads/Aj ... ndbook.pdf
January 22nd, 2015, 11:43 pm
Well, not galvanized.
Cromated - is that the right term?
January 23rd, 2015, 12:31 am
