View unanswered posts | View active topics It is currently April 29th, 2026, 10:33 am
Reply to topic  [ 1048 posts ]  Go to page Previous  1 ... 27, 28, 29, 30, 31, 32, 33 ... 105  Next
 Make Your Own ....2CV.... 4x4
Looks so impressive. I love the seats btw.
May 6th, 2014, 8:41 pm
:lol:
May 7th, 2014, 11:37 am
:D
Car sits level, excellent ground clearance, drive-shaft angles, not extreme (see rear left of picture.)
Front end doesn't hit the bumps stops, with me on the front bumper, will try with 2 people.
May 10th, 2014, 3:40 pm
Using the shock mounts to guess at the length of the knife-edge mounts, has had the following result.
twisted/bent mounts :(
However with the revised longer mounts, the suspension should now be less soft and progressive..
May 15th, 2014, 12:57 pm
Some people have written that the Traction is the best thread at the moment - crap, if you have too much money and spend it like crazy then yes but if you want engineering skills then THIS IS THE BEST THREAD :)
May 15th, 2014, 5:15 pm
+1
No discusion possible.....
May 15th, 2014, 5:22 pm
Nice knife edges
if any one wants to convert 2CV to Ak type front knife edges i got them
as we use a lot of them for the 4x4 when fitting A K springs
i normally fit them up with a special jig to ensure they are fitted in the correct position in relation to the inside of the arm
when i get round to it i will find some fitting pictures on the web
so to make an easy welding job
pony
May 15th, 2014, 7:42 pm
May 15th, 2014, 9:42 pm
To Each His Own ;)
May 15th, 2014, 9:49 pm
Today I used "engineering skills" ;) to fine tune my shock absorber mounts..
With a 1.5 m square tube they bend quite easily.
May 16th, 2014, 5:04 pm
Users browsing this forum: Bing [Bot] and 41 guests
