View unanswered posts | View active topics It is currently April 29th, 2026, 2:08 pm
 Mini Owners - what electrical connector?
Post Mini Owners - what electrical connector?
FAO those of you that have had or do own the other A series, what electrical connector do I need to attach a wire to the back of these switches?
Thanks.
April 11th, 2014, 12:12 pm
Post Re: Mini Owners - what electrical connector?
try these
http://www.vehicle-wiring-products.eu/V ... mepage.php
http://www.carbuildersolutions.com/uk/electrical
April 11th, 2014, 12:23 pm
Thanks.
picture of the BACK might have been helpfull ;)
Lucar on the later ones IIRC its been 30 rs since i had a Mini Bullets on the early ones?
Just get them and then you can work out what you need .
April 11th, 2014, 3:58 pm
I have them (at parental home) but still can't see what I need... looks like 3mm bullet terminals?
April 11th, 2014, 4:06 pm
yep same as the crimp bullets used to fix on to the coil.
April 11th, 2014, 4:10 pm
Ask Dave Boulton on Facebook, or I can pass his number on, he will have the bits you want.
April 11th, 2014, 6:54 pm
scared of the dark
Bullets. Female multiblocks are what is fitted to the car. (like on the back of an 80's D*lly's hazard switch, but round).
Minispares might have them?
Some previous cars:
April 14th, 2014, 3:18 pm
So my learning has taught me this evening that the spades provide (always on) illumination of the switch. Such illumination it hides the decal telling you what the switch does!
On the 2 pin switches the pins are simply + and - and are switched by the switch, handy.
Irritatingly the smallest of my small bullet connectors is too big so I need to work out a way of attaching a cable.
Mini spares do a plug thing but at £5 a go it seems expensive.
Any ideas why minis use spades AND bullets?
April 26th, 2014, 12:12 am
And with the six pin plugs, the top for are switched + and - but weirdly, the bottom two work the other way, i.e. i goes live when the switch is off, is this to switch between circuits?
April 26th, 2014, 12:17 am
BL was a law unto its self the change over to the almost universal Lucar spade conector would have probably sparked a national strike involving Liverpool dockers and London bin men and the panick buying of sugar.
April 26th, 2014, 8:05 am
