View unanswered posts | View active topics It is currently June 19th, 2026, 6:40 pm
Reply to topic  [ 9 posts ]
 Changing body from Dyane to Mehari
Post Changing body from Dyane to Mehari
Been thinking about this for a while - Can I change my body from Dyane to Mehari? Do I need a different Chassis?
March 19th, 2014, 6:22 pm
Post Re: Changing body from Dyane to Mehari
You can; All Mehari where built on a shortened Dyane chassis, You need to cut about 20cm or so of the rear-legs of the chassis, otherwise it is a perfect fit.....
March 19th, 2014, 7:02 pm
Thanks - it all depends upon Japan move - maybe not this year as house here not sold!!!!!
March 19th, 2014, 8:48 pm
were they not "Dyane Mehari" or "Mehari Dyane" originally ?
March 19th, 2014, 9:09 pm
I've seen that somewhere too. Citroen did a lot of that (Dyane6 400, Ami 6 AK350)
March 19th, 2014, 11:39 pm
Citroen's "Characteristics, Adjustments, Checks" tome makes reference to the 'Dyane 6 Mehari'.
I'd guess that the official commercial symbol being 'AY Series CA' contains a clue, mind you... ;)
March 20th, 2014, 12:48 am
Whats the plan on space frame bit at the back? Buy new or make one yourself?
Ive repaired a couple of them over the years, if you can get some dimensions then not too tricky to fabricate one that will do the job.
March 21st, 2014, 9:53 am
No, just find somebody with a Mehari who you could swap with ;)
Except I don't think I could. I have a something of a sentimental/emotional attachment to it... :roll:
March 21st, 2014, 11:11 am
If you mean this little lot - then buy new galv
http://www.mcda.com/119-berceau-tubulaire-mehari
March 21st, 2014, 5:44 pm
Users browsing this forum: Google [Bot] and 197 guests
