View unanswered posts | View active topics It is currently February 4th, 2026, 12:23 am
Reply to topic  [ 290 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9, 10, 11 ... 29  Next
 The Dirty 'D'
Post Re: The Dirty 'D'
All out....
It was a lot more rusty than i expected... mainly being held together by sealant ...
www.evilbens.blogspot.com
October 5th, 2013, 9:56 am
October 5th, 2013, 9:58 am
The rear deck all cleaned up and bolted down on the chassis....
October 5th, 2013, 10:00 am
New side panels made to drop down from the rear deck back onto the sill panel, the new floors lined up and bolted up then welded into place. Notching around the B post seemed a slow process i did not want to cut out to much in one go...
October 5th, 2013, 10:05 am
I want it to look as factory as possible..
October 5th, 2013, 10:07 am
The boot floor will need some work to get right and will have to be welded to the rear panel 8cm higher ... at least the welding marks can be hidden behind the number plate and back lights :)
October 5th, 2013, 10:10 am
Test fitting the rear bench... No room for tall people with the roof up...
October 5th, 2013, 10:12 am
So there it is so far...the rear arms are hard up against the inner wings at the back so they will need cutting back, the rear inner wings may need to be moved if i wish to keep the larger rear tyres not sure yet it may end up on a different set of wheels too....
But i am happy with the progress made...in fact i have loved every minute .
October 5th, 2013, 10:20 am
Oh yes thank you Wiltz... the front panel is perfect.
October 5th, 2013, 10:21 am
8-)
October 5th, 2013, 10:31 am
Users browsing this forum: No registered users and 605 guests
