View unanswered posts | View active topics It is currently May 8th, 2026, 12:52 am
Reply to topic  [ 249 posts ]  Go to page Previous  1 ... 17, 18, 19, 20, 21, 22, 23 ... 25  Next
 sidney has entered the building
Post Re: sidney has entered the building
haha ! :lol: good to be in intelligent company at least! zee great minds zay sink alike :lol:
I´ll have a go at the fade out when I get more paint, I ran out..oh and by the way they´re not decals its all hand painted ;)
cheers sig
September 19th, 2013, 9:18 am
Sorry, I knew that they were hand-painted - poor choice of words :oops:
Enjoying the thread, especially the pictures - all nicely done 8-)
September 19th, 2013, 12:10 pm
hmm! rear brake cylinders, shoes and springs all done, bled and I think adjusted correctly, but its still a death trap. only brakes on front right.
can someone tell me if the 14mm shoe adjuster nuts tighten clockwise or anticlockwise, and is it the same on both left and right or are they handed?, I forgot to look when the drums were off
are there any tricks to get the new shoes binding in well, quicker?
doesnt seem to be leaking anywhere.
todays other news...the upholstery is going in slowly and look slick, but I´ve got other work on and I´m putting the lambretta in primer at the same time so Its all slowed down.
once the brakes are working properly I just need the wiper washer system to work(mines got a push hand pump thing thats duff at the moment
and the horn switch changing
then its ITV test time :shock:
September 25th, 2013, 6:56 pm
Have you got eccentrics at the pivots, or concentrics?
The snail cams go "out" to move the shoe out, all four of 'em.
Have you got lots of wasted travel at the pedal?
September 25th, 2013, 7:03 pm
err, no idea they look like snails ??
yes 3 pumps before anything really happens :?
so anticlockwise on the front sides and clockwise on the backsides?
September 25th, 2013, 7:16 pm
Each shoe has a boss (7) slotted into it at the bottom. Originally, that was eccentric with a hex. A lot of people have fitted concentrics without. Which of those have you got?
If it's the hex eccentric, then you're going to need to use an adjustment tool.
If it's the round concentric, then it's easier to fit but you won't get such good brakes.
Then there's the snails at the top (8) with the adjuster bolt through the back plate.
That's all the same front and back.
Then, on the front, you've got the handbrake cable adjustment as well.
Either they're MILES out of adjustment or you've got lots of air still in the hydraulics. Or both.
Yep, assuming they've not seized, been replaced but cocked up - but sort the eccentrics first.
September 25th, 2013, 7:26 pm
sig, with a single hex socket and a fixed breaker bar ( ratchets are too fiddly - spose a spanner is ok) when placed on the hexagonal headed adjuster in a horizontal position, its down to tighten up to loosen, irrespective of which side or hand its on.
September 25th, 2013, 7:40 pm
perfect help guys thanks.
ok the shoes I took off had the hex pivot, and the new ones they gave me were simple rounds..hence my confusion, never even knew it was variable at the bottom.
will try bleeding again and adjusting tomorrow. maybe my 8 year old daughters legs weren´t long enough to push down hard enough! :D
September 25th, 2013, 9:11 pm
They both just push out of the shoe - I'd use the eccentrics and take the little bit of extra effort to set 'em up.
September 25th, 2013, 9:23 pm
bleeding brakes abc....
A) build pressure on the pedal (pump fast several times till theres pressure)
B) loosen the bleeding bolt at the cilinder, pedal will go down quickly, when pedal is at the floor keep it there;
C) tighten the bleeding bolt; release the pedal...
go back to A.......
Go on till there aren't any airbubles comming out
Don't forget to fillup the reservoir otherwise you can start over.....
start with the right rear cilinder, then left rear cilinder, front right cilinder and if there is left front cilinder........
September 25th, 2013, 11:01 pm
Users browsing this forum: No registered users and 118 guests
