View unanswered posts | View active topics It is currently April 28th, 2026, 1:45 am
Reply to topic  [ 880 posts ]  Go to page Previous  1 ... 48, 49, 50, 51, 52, 53, 54 ... 88  Next
 1-2-spark
Post Re: 1-2-spark
Will look at the video
Ive heard it described as walking on cornflakes but ive never heard it. Sometimes i think i hear it but im not convinced (when i was on points and condensor) i hear a slight not thud but like noise which i thinks normal
Geo what numbers can i put thatll definatly pink? So i can learn properly
I also assumed small numbers = more advance
July 9th, 2013, 9:53 pm
Post Re: 1-2-spark
Where are you based? If you want to come over to Oxfordshire I can help set it up.
There are a few great hills to tune it on.
July 9th, 2013, 10:07 pm
Post Re: 1-2-spark
Sounds good. Im ony availble next on july 28th though.... Unless evenigs are ok?
Are you coming south at all?
Cheers mark
July 9th, 2013, 11:19 pm
Post Re: 1-2-spark
About 100 miles away so maybe july 28th is the soonest...
Or are you at snetterton?
July 9th, 2013, 11:23 pm
Post Re: 1-2-spark
Cheers mark
I'm going South to Spain but I assume that is not what you mean!!
Evenings are fine.
I'll PM you.
July 9th, 2013, 11:26 pm
Post Re: 1-2-spark
Cheers
July 9th, 2013, 11:28 pm
Post Re: 1-2-spark
ken wrote:
Exactly so... ;)
http://www.youtube.com/watch?v=GGJZ6kKzLus
With the 2CV's twin cylinder engine, the crackling isn't as rapid as on other engines.
Unless the timing is a mile out. :roll:
Saurus wrote:
In mine (with regular ignition) it was a quiet but also distinct sound easily heard over the noise, like walking on dry leaves or something like that, fast crackling sound.
Just watched the video. Didnt realise just how evident pinking really is...
July 9th, 2013, 11:46 pm
Post Re: 1-2-spark
some want to stick with a pushbike others want to go forward!
I aggree that verry often simple is the best, but this is such an improvement compared to original or other electronic ignitions.. this one you can adapt to your specific engine (and the youngest one beïng about 25 years old, there will be some 'differences')
if you dont want to put any time in adjusting something like this, just stick to the other availible ignitionsystems!
greetzzzzzzzzzzzzzz
bitten by the Citobug...
July 10th, 2013, 8:23 am
Post Re: 1-2-spark
As of today, my 2CV is running on 1-2 Spark. It's absolutely awesome. Here's some ideas for sensor mounts etc.:
I'm using a Fiat double coil, with a 3,3 ohm 100W resistor (it has only 0,5 ohm resistance by itself and would try to draw a HUGE current)
July 11th, 2013, 9:24 pm
Post Re: 1-2-spark
If I had to pick the one aspect of I2F that pleases me the greatest then it's this thread.
July 11th, 2013, 9:51 pm
Users browsing this forum: No registered users and 131 guests
