devontdi
 very lumpy at low revs
hello all, new to this forum. proud new owner of '88 2cv, it has been sat in a shed unused for 14 years.
having trailered it home i have set about getting it running and back on the road.
having replaced points, spark plugs, condenser, oil, filters, fuels lines, adjusted valve clearances, the car starts first turn of the key and idles really evenly. my problem is that when i depress the accelerator the engine is really lumpy as it gains revs at lower end, runs fine once at steady rpm, anything obvious i am missing,
thoughts would be much appreciated,
Steve
| May 14th, 2013, 10:15 pm |
smyth602
Haggis Muncher
Joined: September 13th, 2012, 7:38 pm Posts: 571 Location: Denny, Scotland
 Re: very lumpy at low revs
Sounds like it could be the accelerator pump to me - it squirts some extra fuel into the carb when you press the accelerator to help it along until the revs pick up. If its not working that could be your problem.
Take the rubber pipe from the air filter off the top of the carb and look into it as you operate the throttle control. You should see a squirt of fuel going in if the accelerator pump is working.
| May 14th, 2013, 10:49 pm |
Or operate the accelerator pump lever directly, pushing it downwards away from its cam. It's very common for this part of a carburettor to be 'lazy' after an extended period of storage, but spraying it with WD40 and operating the lever by hand will usually restore things to how they should be.
| May 14th, 2013, 10:56 pm |
Devils Advocate
Steve, do I take it by your username you are in Devon?!
| May 14th, 2013, 11:09 pm |
devontdi
Thanks for the tips, I will check out tomorrow.
Yes DA. I am in Devon.
| May 14th, 2013, 11:13 pm |
Neil
 Re: Happy Birthday
Devils Advocate wrote: Steve, do I take it by your username you are in Devon?! Or perhaps a Volkswagen Transporter/camper owner?
| May 14th, 2013, 11:17 pm |
devontdi
I had a camper a while back, as well as a Charleston back in '94, until someone drove into it and wrote it off. Always wanted another 2cv, so here it is. Just hope to get it on the road asap.
| May 14th, 2013, 11:22 pm |
devontdi
thanks for suggestions, I have given the accelerator pump good clean and lube and its revving lovely now.
| May 15th, 2013, 7:53 pm |
Devils Advocate
Nice job, devontdi.
I'm near Bideford, by the way. If there's anything I can do to help - tho' I'm certainly no expert - please ask.
| May 15th, 2013, 10:10 pm |
devontdi
Thanks DA. I am down in Newfton Abbot. I expect there will be more obstacles I will need advice on. Thanks for all responses. What a great forum.
| May 17th, 2013, 10:23 am |
Users browsing this forum: No registered users and 226 guests |
