View unanswered posts | View active topics It is currently April 28th, 2026, 4:24 pm
Reply to topic  [ 3 posts ]
 Nuts
Post Nuts
Running out of manifold exhaust copper nuts. Before looking at getting new stock I would like to know what is best for heat, copper or bras, maybe something else. We all know that old exhaust copper nuts are slowly burning away and can be a pain in the arse to remove.
What is this stud made off, seems to be harder or coping better with the heat
October 14th, 2009, 10:48 am
Post Re: Nuts
Viking,
the 'copper' nuts which I've used in the past seemed to be copper plated, whereas the brass nuts now available are solid, so a much better bet.
Exhaust manifold studs are likely to be high tensile steel, perhaps 10.9 grade...
October 14th, 2009, 11:15 am
Post Re: Nuts
Thanks Ken. I somehow knew the answer. Will find some bras nuts.
Cheers
Viking bastard
October 14th, 2009, 11:38 am
Users browsing this forum: No registered users and 105 guests
