View unanswered posts | View active topics It is currently April 30th, 2026, 1:26 pm
Reply to topic  [ 3 posts ]
 Used Pistons and Barrels
Post Used Pistons and Barrels
Have a used set of pistons and barrels.
There is no ridge on the barrels.
What sort of tolerance is ok?
Worth fitting new rings?
October 14th, 2009, 11:04 am
Post Re: Used Pistons and Barrels
Very simple. Fit new compression ring inside the worn barrel and measure the end gap max 0.35mm. If bigger then barrel is worn (out) I would bin it.
October 14th, 2009, 11:36 am
If it was even slightly worn, there'd be a ridge, though...
October 14th, 2009, 2:59 pm
