| Non 2cv Brake question http://international2cvfriends.com/forum/viewtopic.php?f=7&t=856 |
Page 1 of 1 |
| Author: | Simon Crook [ September 19th, 2009, 9:05 pm ] |
| Post subject: | Non 2cv Brake question |
Sorry I know its not a 2cv question, but you tech boys are a clever bunch cheers |
| Author: | Devils Advocate [ September 20th, 2009, 9:36 pm ] |
| Post subject: | Re: Non 2cv Brake question |
You don't have a set of anti-squeal shims or springs still sitting on the ground where you did the job? Failing that, possibly down to new pad material which is asbestos-free? Are you 100% certain the pads you bought are compatible with your original discs - I understand asbestos-free pads are harder than the old types and the discs use a softer metal to 'compensate'. Pure speculation on my part, tho'... Oops, just re-read your post - you fitted new discs as well? Possibly just a side effect of the new material. I know they take a while to bed in, but it looks as tho' you've already assisted this with the sand paper. Did the pads look as tho' they had a different coloured coating on their surface? I have read that some have this 'abrasive' surface to quicken the bedding-in process and to get them to 'match' the disc surface more accurately (possibly a bit like 'honing' cylinders when new rings are fitted.) Still guessing... Ask the supplier, or email the actual parts manufacturer. |
| Author: | Simon Crook [ September 21st, 2009, 4:58 pm ] |
thanks for the advice DA |
