Page 1 of 1
[ 6 posts ] |
Ianredspecial
 Axle Boots
Just a thought, but I replaced my front axles with Ecas ones some time ago. And then as has sometimes been the case, wished I hadn't. They make clonking noises at certain angles and stuff. Recently I thought I might need recovery due to an awful noise. I was away but bought a grease gun and that was the fix.
I grease them more often than schedule.
So my question is, is it normal for the grease to come out of the ends of the boots much? Mine gives under the wings a good spattering every time I grease. Maybe the ends just aren't tight enough. From memory I didn't use those Ligarex fastenings, or whatever they're called. I don't remember what I used now, maybe strong plastic ties.
| September 19th, 2025, 9:45 am |
AZL57
 Re: Axle Boots
Plastic ties on the driveshafts lenghten when warm and you loose grease. Metal clips are better.
| October 16th, 2025, 6:37 pm |
Ianredspecial
 Re: Axle Boots
That makes sense.
| October 18th, 2025, 10:04 am |
Roger V
 Re: Axle Boots
See if you can tighten them with some grips on the end of the tie
| October 18th, 2025, 2:00 pm |
Taskos
Joined: February 22nd, 2012, 10:34 am Posts: 424 Location: Greece
 Re: Axle Boots
Just make sure there is no crack on the boot itself.
| October 19th, 2025, 8:07 pm |
Ianredspecial
 Re: Axle Boots
Thanks all. I'll have a look.
| October 20th, 2025, 10:19 pm |
Page 1 of 1
[ 6 posts ] |
Users browsing this forum: Google [Bot] and 199 guests |
