View unanswered posts | View active topics It is currently April 26th, 2026, 11:30 pm
Reply to topic  [ 7 posts ]
 axle arm castellated nut - tightening it up.
Post axle arm castellated nut - tightening it up.
Hello - I've been working on my axle arm bearings - I've changed out the old rusty ones, re-greased and am reassembling. Has anyone got a method for tightening up the castellated nut - the manual say tighten to 43ft.lb, back off, then tighten to 36ft.lb. I don't have a suitable socket - so am looking for something involving tapping the nut around with a drift.
March 8th, 2024, 12:31 am
Post Re: axle arm castellated nut - tightening it up.
Buy a torque spanner !
it always comes in handy .
I have three of them, a small one, one with more torque and one with even more torque.
Nowadays they are not that expensive.
edit:
Ups, i did not read it properly
March 8th, 2024, 8:40 am
Hi,
if you've gone to the trouble of buying new bearings etc. then what's another £32.00 plus p&p for a lock ring tool? :D
Seriously though, drifting it will work but if you are in the 2cvgb club then asking your local group to borrow one would be best.
Good luck :)
March 8th, 2024, 12:01 pm
ummm. The burton tool @£32, https://www.burton2cvparts.com/en/rolli ... cknut-tool, does not have a 1/2" female for a torque wrench! It just has 4 holes - for a screwdriver it says! No different to a drift.
March 9th, 2024, 2:39 am
Make something yourself with a few pieces of angle iron with an old socket welded on top??
March 9th, 2024, 11:51 am
I should have said that a suitable nut should be welded on top of the expensive tool. I made my own.
ImageIMG_2889 by Robndaisy, on Flickr
ImageIMG_2891 by Robndaisy, on Flickr
March 10th, 2024, 12:51 am
Yes, lovely ... that's the answer.
March 10th, 2024, 12:49 pm
